Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How to change ink cartridge on Epson SX100? - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
  • 122 Answers
Lift the whole top section up (from under the scanner bed) and the ink cartridges will move to the centre allowing you to lift the plastic clip up and remove and replace the cartridge. DO NOt try and drag the cartridges to the right place. It should do it automatically provided the cartridges need changing. Good luck
Posted on Jul 15, 2010
  • makinmagic Nov 29, 2010
    Switch on, wait for it to settle, open it, if any activity wait for it to settle again, press stop button and the head will move (probably to left of centre), wait for it to settle again then press stop button again and it should move to the correct position for changing cartridges.
    The "official" instructions were very misleading.
websnail
  • 419 Answers
SOURCE: remove ink cartridge
There should be a procedure for changing the cartridge and checking the manual indicates this routine:
1. Open the printer lid to give you access to the printer insides.
2. Press the "Stop" button (a picture of an reversed triangle in a circle)
3. Wait for the cartridge carriage to move into the replacement position.
4. Replace cartridges
5. Close printer lid
6. Press the "Stop" button again.
If that doesn't work you can always start the printer, wait until you hear the sound of it starting to move, pull the power cord on the back of the printer and then open it up. Hopefully the carriage should be in a position where you can move it and get to the cartridges to replace them.
I wouldn't recommend the latter approach unless you can't get the main routine to work correctly.
Posted on Jan 23, 2009
  • 357 Answers
SOURCE: Ink cartridges not working in epson sx100 all in one printer
Make sure that you have removed the tape on each cartridge.
make sure the cartridges are for your model printer as they are not all the same.
The cartridges could be bad since they are remanufactured, you can go back to the place you bought them and see if they will replace the cartridges for you or you can look online for a cheaper price like www.meritline.com
Posted on Feb 06, 2009
kevin000
  • 1847 Answers
SOURCE: Epson RX420 has all lights flashing + E in the display, Have just changed ink cartridge and problem occured
OPEN SSC UTILITIES,DROP DOWN CONFIG BOX,SELECT RX420 MODEL,CLOSE BOX,THEN RIGHT CLICK ON TRAY ICON AND SELECT INK FREEZER,AND RESTORE VALUES BACK, OK ON COMPLETION,THEN RESTART YOUR PRINTER AND ALL SERVICE LIGHTS SHOULD BE OFF.
IF YOU HAVE ANY FURTHER ISSUE LET ME KNOW
THANKS
KEVIN
Posted on May 05, 2009
SOURCE: How do I change an ink cartridge on an Epson SX100
I have no instruction manual, the black ink has run out, I have purchased a replacement, and now l need to install it.
How ?
Brendan
Posted on Jun 25, 2009
SOURCE: Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
Posted on Oct 14, 2009
How do I get cartridge holder to move to change position?
Hi there bud. Don't worry. Explaining it via text wouldn't be the ideal way so I attached a link to a easy video guide , please do watch it . Hope it will help ya. Good luck!
Note :
This is the best video guide I found and it's for everyday general printer .
Aug 02, 2016 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Ive changed ink cartridges and still ink light is flashing and not printing
Chances are you are either;
1. using an "expired" ink cartridge. or
2. the Chip on the ink cartridge is erased and will not work.
Many re fillers do not reset the chip after refilling them.
This is Epson's way of saying "I do not like compatible, refilled cartridges...I hope this helps, Happy Holidays...Steve at TakeCharge ReCharge
Oct 22, 2015 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
How do I replace a nearly done black cartridge in my Epson SX100 it is hard to read the print
To change an empty ink cartridge on the Epson Stylus SX100, make sure that the printer is plugged in and turned on. Next lift the entire scanner unit (pull up from the center); make sure that the document cover is closed. The support arm should engage. Next press Stop (above the Copy button). The ink cartridge carrier should move so that the (first) empty cartridge moves to the spot with the droplet with a slash through it symbol. Press the tabs on the front and back of this cartridge and pull it straight up. Shake the new cartridge while it is still in the package. Then remove it from the packaging and remove the yellow tape without touching other parts of the cartridge. Slide this cartridge into the open slot and press down until you hear a click. Press Stop to advance the carrier to bring the next empty ink cartridge into the empty cartridge position. When done, lift up on the scanner unit and disengage the support arm by pushing it in towards the printer. Then lower the scanner unit. Press Stop again to get the printer to run through the maintenance step.
If you want to change the ink before the printer indicates it is out, you need to open the Epson Status monitor software. With a Windows OS, go to the Maintenance tab and find the Ink Replacement utility. Launch the utility and follow the on-screen directions and open the printer, as above. It this software isn't installed, then you need to check if the software is available for your OS. Install the software, if it is available. Please add a comment with the OS on the computer connected to the SX100 for more information.
I hope this helps.
Mar 23, 2015 | Epson Office Equipment & Supplies
Change cartridge before its finished on epson stylus sx100
  1. Do one of the following:
    • Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Then click the Maintenance tab.
    • Macintosh: Open the Applications folder, open the EPSON Printer Utility 2, select CX7400 Series, and click OK
  2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Sep 08, 2014 | Epson Stylus Office Equipment & Supplies
Need to get ink cartridges out of my epson stylus SX100 how do i do this
Turn printer on and print something. When the printhead/cartridges are out in the centre, switch off at power point or pull the plug out. You can then move the printhead by hand and remove/replace the cartridges.
Then just connect the power cord or turn the power back on.
Aug 19, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epsom sx100 keeps saying cartridges are not compatatble but are using epsom inks
If you have Genuine Epson cartridges and they do not work, call Epson Tech Support. You have to be patient [they're in India] and you may have to ask to speak to someone in the US if you're getting nowhere with TS.
Oct 06, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Ink light and on/off light flashing
Turn printer off for a few minutes then turn back on. If still flashing your cartridges may not be compatible.
Jul 17, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
I cannot change my ink in my Epson Stylus SX100. There is not a button to push where the ink drop is on my printer scanner. Can someone please help me. Thankyou
If you need to replace a cartridge when the nx100_tx100_ug.1.92.1.jpg ink light is flashing or off, you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the nx100_tx100_ug.1.92.2.jpg printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab. Macintosh: Open the Applications folder, open the EPSON Printer Utility3, select your printer (if necessary), and click OK. You see one of these screens: nx100_tx100_ug.1.92.3.jpg 2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Nov 02, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to change all ink cartridges in SX100 model Epson please
i have substitute original color and black cartridges but it doens't recognize same, what can i do?
Mar 03, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
4,705 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
