Question about GPS
I LEFT MY TOMTOM N14644,CONNECTED TO MY COMPUTER OVER NIGHT TO FULLY CHARGE,BUT IT WILL SWITCH ON,GREEN LIGHT IS ON I HAVE TRIED HOLDING DOWN THE ON/OFF BUTTON FOR OVER 15 SECS, DO YOU THINK I HAVE DAMAGED THE BATTERY ?
  • 6,993 Answers
the fault is obviously from the battery. Its must have been damaged as a result of over charge. Or maybe the battery wasn't even charging in the first place. It might have discharged.
Which ever the case maybe, the cause of the problem is the battery. It may be damaged or not charged you thought.
Try to charge the battery through another source apart from the computer or test the unit with another battery.
GOOD LUCK.
Posted on Jul 15, 2010
Go 730 green light on but nothing happens
Have you tried resetting, either by
(a) holding down the Power ON/OFF button .... a long time ... until the unit shuts down and starts up again, or
(b) pushing a pin into the RESET hole)
after the TomTom has been fully charged ?
Aug 28, 2013 | Tomtom GO 730 Car GPS Receiver
My tomtom one n14644 will not turn on we've tried everything i even plugged it into a computer to see if anything pops up but no response but the green light on the bottom...what can i do?
If this doesn't work, you can reset your device. To do this, press and hold the Power button for fifteen seconds. Release the Power button when device begins to restart.
Aug 16, 2010 | Tomtom ONE GPS Receiver
My tomtom one (4n00.012) not working i try to charge it since last night but still the green light is in but it doesn't switch in ,i don't know maybe because i left 3 night inside the car and the weather...
hi nid_57 have you tried a soft reset. go to tomtom.com, select support, search for reset, select soft reset, select your device and do what they tell you. almost ever works fine. greetings
Feb 19, 2010 | Tomtom ONE GPS Receiver
How do I reset my TOMTOM N14644?
Go to TOM TOM´s homepage http://www.tomtom.com/services/
Connect the GPS unit to the PC using the USB2 connection.
You will be given the possibility to restore the unit´s files. This takes a while, but it solved the problem for me.
Nov 04, 2009 | Tomtom ONE GPS Receiver
TomTom Go 910 comes on, then goes off
Sounds like a dying battery. There is not enough charge being maintained in the battery to complete the loading of the data. ChaNGE THE BATTERY
Jul 20, 2009 | Tomtom GO 910 GPS Receiver
Hi my tomtom 910 go wont switch on ], but when useing the charger the little green light lights up and will stil not switch on ive tries the hard resetting and does not work
I've had a similar problem on 2 TomTom 910s.
First, try holding in the reset button while holding the power switch down for 5 seconds.
If that doesn't work, let it charge for 12 hours and while it's still charging, hold the power switch down for 5 seconds.
It worked for me on both
Good luck
Jun 07, 2009 | Tomtom GO 910 GPS Receiver
Won't switch on
Connect it to the computer, then try to switch it on by pressing the button for 1-2 seconds. If it switches on, connect to tomtom home, update, and then switch off. Disconnect, then switch on again. You may have to reset it again by pressing the button for 10-15 seconds. I onl had this problem once, after my first download from tomtom home - I think I crammed too much info into its memory!
May 18, 2009 | Tomtom ONE XL GPS
My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
May 12, 2009 | Tomtom GO 720 GPS Receiver
GPS Logo
77 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
