Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
The monitor shuts down after being on after 10 minutes. Then will blink on and off.
Viewsonic v1930wm
Sounds like the unit needs repair.
Jun 23, 2014 | ViewSonic VX924 19" LCD Monitor
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
Dryer runs for 10 mins and shuts off.
Your dryer motor has a thermal overload built in to it. If your symptom is shutting down allow to cool and it works again for a few minutes the shuts down again.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Frigidaire Dryers
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
HP Monitor w1907 problem
First place to check will be the power supply section, look for bad caps with bulging top or bottom seal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | HP w1907 LCD Monitor
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Panasonic Th37PE30 Viera plasma stopped working
here is a complete list of all codes for panasonic tv's rgeardless of model if its panasonic it is these codes
1 Blink SOS: This shutdown operation is usually caused by a lack of communication between the A and the D boards.
1 Blink SOS: This shutdown operation may be caused by the improper connection of a SS board connector to the panel.
2 Blinks SOS: Pin 87 of the MPU IC9003 monitors the 15V line. During normal operation, the transistors Q9053 and Q9054 output a high to pin 87. If the 15V line is missing or shorted, a low is provided to pin 87. As a result, the unit shuts down and the power LED blinks 2 times.
3 Blinks SOS: IC9807 is a 3.3V regulator located on the D board. Its output is monitored by IC9003. If the 3.3V is not present at pin 86, the MPU shuts down the unit. The power LED blinks 3 times.
5 Blinks SOS: Pin 85 of the MPU IC9003 monitors the 5V line. During normal operation, the transistors Q9051 and Q9052 output a high to pin 85. If the 5V line is missing or shorted, a low is provided to pin 85. As a result, the unit shuts down and the power LED blinks 5 times.
6 Blinks SOS: Pin 90 of the MPU IC9003 monitors the status of the SC board. During normal operation, the transistor Q6581 and IC6581 output a low to pin 90. If the SC board becomes defective, a high is provided to pin 90. As a result, the unit shuts down and the power LED blinks 6
6 Blinks SOS: 6 blinks of the power LED may also be obtained from pin 3 of IC9003, the DRV_RESET input. The D board provides the 5V source needed to power the C boards. On the C2 board, the 5V is routed back to the D board via connector C20/C10, C11/D31 causing pin 3 of IC9003 to be high. If 5V is not routed back to the D board, pin 3 of IC9003 goes low. The set goes into shutdown mode and the power LED emits 6 blinks.
7 Blinks SOS: Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
8 Blinks SOS: Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
10 Blinks SOS: The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS: The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
Feb 26, 2008 | Televison & Video
Panasonic Plasma TH-42PZ77U Power Light Flashing 7x
Dec 31, 2007 | Televison & Video
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
67 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
