Question about Sharp AR-M257 Black and White Copier
What do i do to solve error code F5:02 on sharp Ar-205?
    President:
  • 2,072 Answers
F5-02 means the copy lamp is not on or not bright enough.
Remove the glass and clean all the optics in the scanner including the lamp, if it is coming on that is. Make sure you clean the bottom of the glass, the white strip on bottom well.
You can also press # * C * and the machine will go into diagnostics,
then enter 14, then 1 and execute. then 15 , 16 , 17 and execute those fault clearing procedures.
If the lamp is bad let me know I can get the part number for you.
Posted on Jul 15, 2010
    Problem Solver:
Till same indicate
Posted on Nov 29, 2011
4 Suggested Answers
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
SOURCE: i have a sharp photocopier AR-5316 flashing error
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Posted on Jun 06, 2011
SOURCE: Sharp AR-163 Copier, How to Reset/Solve the error
how to clear red sing on tonal problem for sharp ar 163
Posted on Sep 19, 2011
MY PROBLEM IS ERROR CODE M2 PL SOLUTION
Here is a website that has a list of Sharp Error Codes
Also here is a list of the drivers and copies of the
Sharp AR-M-205 owners manual and drivers
Hope this helps
Nov 30, 2012 | Sharp AR-M205 Copier
My sharp copier AR-5320E is displaying error code u2
U2 04 Content EEPROM serial communication
error
Detail Error in communication with
EEPROM
AR-205
Jul 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR M-205 Blinking U 2
E prom error
Hold down the START button and retrieve the SUB-CODE,
EXample 04 or 11 or 12 or 40 ,
To clear:
Press #(button) interrupt(button) C(button) interrupt(button) within 5 secs.. then press one six (16) start (key)
Jul 10, 2010 | Sharp AR-M205 Copier
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Sharp AR-M257 Black and White Copier Logo
1,329 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
