FixYa.com
Tags:
Whirlpool Calypso GVW9959K Top Load Washer
Washer will drain druning the initial spin but not...
posted by ebaer on Apr 20, 2008
I get either an LD code or a C1 code. Since it drains initially, I don't think it is the pump, but maybe and issue with the electronics. Also it dosn not add the fabric softener.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 13, 2008
Helpful (85)
UTEngineer
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
LD is a Long Drain code. You mentioned that there is an initial drain so this could be due to some lint or debis caught up in the drain line or drain tank. You will have to remove the black drain line and inspect to make sure all is clear. If you hear a humming noise while the cycle is in the drain cycle, your pump gears could be stripped. If this is the case - the pump will need to be replaced.
The C1 code is a motor current error. The source of the problem might be the motor, but will take more detailed electrical troubleshooting to find out.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
The washer wont fill up with...
The washer starts washing... Answer This...
calypso problem
ever get this peroblem fixed?... Answer This...
Problem with Calypso
Did you ever get a solution to... Answer This...
Calypso displaying SL or5L...
I'm having the same problem you... Answer This...
Tangles Clothes, cannot adjust...
If there is a class action... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
