Question about D Cut TD-080 Wet Tile Saw
Were can i purchase a d cut td-080 wet tile saw in the uk
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
What is a wet saw? is it easier to use than a tile cutter?
Wet saws make cutting thick or strong tiles easier, they also make it easier to make multiple cuts on a tile. It takes longer to use the wet stone so if you don't really have to use it then cutting with a tile cutter will go much faster.
Nov 17, 2013 | Cutter Tools
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
Czo@shawhow do you keep the drain plug in poistion
sometimes its easier to put the drain plug on the bottom side up,makes it easier to drain the saw without having to pull the whole thing apart to get at the drain plug,goodluck
Feb 13, 2011 | D Cut TD-080 Wet Tile Saw
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Wet saw not cutting material completely
It might need a new blade. But try putting an old tile or offcut behind the tile you are cutting. Make sure the table surface is clean and flat. Residue tends to build up around the front of the blade which could cause the tile to crack. The ryobi's have a habit of water getting into the motor and the bearing destroys itself. Next time you take the blade off, take of the blade support and put bearing grease behind the rubber washer. I've blown up two this year until I worked out what the problem was.
Apr 25, 2009 | Saws
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
D Cut TD-080 Wet Tile Saw Logo
56 people viewed this question
Top D Cut Saws Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a D Cut Saw Expert? Answer questions, earn points and help others
