Question about GE AJCQ08ACB Air Conditioner
The hose to the air conditioner keeps on freezing and blows air sometimes what should i do? also replaced filter n put new rewireing
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
What is the problem when an air conditioner begins to freeze up?
Freezing up is caused by
•dirty air filter or evaporator coil(indoor coil)
•dirty blower wheel or blower fan blades
•low freon
•weak or slow blower motor
If air filter and indoor coil are clean may be low on freon. Blower wheels seldom get dirty on window units. Pull unit from window and clean both coils with a water hose. Careful not to get any electrical wet. Let dry for a while and reinstall. If it continues to freeze its a freon problem most the time.
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Ac unit is not cooling, the part on the inside keeps freezing up after it is frozen the air blowing is not cool. Sometimes there is a knocking sound from the compressor.
Freezing of the evaporator is caused by low air flow (fan problem or dirty filter),low refrigerant charge or leak. I would suspect a leak (noisy compressor) because the compressor lubricants are in the refrigerant.
Sep 29, 2013 | Heating & Cooling
The lines on my air conditioner keep freezing and its not getting cold but the compressor keeps coming on
If your vents inside are blowing normal and your filters are clean, more than likely you are low on refrigerant and it will have to be charged. Also check to make sure the fan motor outside is working when the system is on. Hope this helps!
Jun 19, 2012 | LG Heating & Cooling
I have a Ruud A/C. For 4-6 hours my air conditioner blows cold air, then it it starts to blow hot air after that. Happens like this every day. What can it be
Check the indoor coil to see if it is icing up, if so clean the evap. coil filter ect. you have to have good air flow or it will freeze up. Setting the stat. to low below 72 degrees will do it as well, because your coil would be below 32 degrees. If that worked clean your condenser coil too. take a hose to it a solid stream and hose it clean, be thorough get very inch.
Jul 05, 2011 | Heating & Cooling
Ice builds up just inside the air filter, making the unit not as effective.
Unit needs to be cleaned. When unit and filter is dirty , air can not get through. It needs to be blown out with air compressor, or, you can even hose it out. ( IF HOSING NEED TO PROTECT ELECTRONICS TO NOT GET WET.) after hosing, then let completely dry, help dry time by using air compressor, to blow out excess water. Then fire that baby up as long as dry and should cool and not freeze. If it still freezes up, then it still not getting good air flow. Thanks Mike from fixya
mc1bean_40.jpgIf i cant fix it, its not broken!
Jun 29, 2011 | Samsung AW0505M Air Conditioner
My unit keeps freezing. How do I stop it?
First, make sure you have it set at a mid temp. Eventhough the thermostat says it will make ice cubes, it isn't supposed to. The unit should cycle on and off with a room temperature of 70 - 72 degrees.
Secont, make sure that the filter and the insode and outside coild are clean. If they are dirty, wash the filter and gently bruch the coild, being careful not to flaten teh aluminum fins.
If you are handy, take the unit outside, remove the cabbinet (and with it UNPLUGGED), spray it down with a garden hose, running water through both coils. Let it dry fro a few hours, put the cover back on and put it back in the window.
If you still get icing, you probably have a low charge. With the cost of labor, and the price of window units, you'ld be better off replacing it than fixing it, unless you have a local air conditioning school that will do it for cost of materials.
Jul 19, 2010 | Frigidaire FAC124 wall/Window Air...
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
Ice on the hose and not very cold
It does sound like it is losing charge. Unfortunately, most window units don't have charge ports. And the price you pay to have a guy put a port in and charge it would be more than the cost of a new unit
Jun 23, 2009 | Whirlwind FH-778 Air Conditioner
Freezing up
I suspect your air filter is clogged with dust. The front inside panel of the air conditioner should be removable. Take it off to get at the filter. The filter for most of these window units looks like a thin piece of foam. Take this out; rinse off all the dust in a sink or outside using a hose, and then reinstall it. Hopefully this will fix your problem.
Jun 12, 2009 | Whirlpool ACC108PS Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
