Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
When doing wash softener is not going out of drawer properly & leaves water in draw help!!
    Brigadier General:
  • 3,006 Answers
The softener dispenser has a blockage, it's very common these days and some brands of softener are worse than others for causing it.
Pull the drawer completely out of the machine. Flip up the cover over the rear half of the softener dispensing compartment. Thoroughly clean out all of the (usually black or pink) goo which is causing the blockage.
The softener dispenses on a siphon principle, so there's a blind-ended upper tube moulded into the cover which fits over a lower tube. The lower tube is easier to clean out as you can pass pipe cleaner brushes or similar right through it, the upper tube will be trickier as you need to winkle out every bit of goo from just one end. The goo is a biofilm, so if there are any traces left then it will rapidly re-grow.
Note that if you look carefully at the way the front panel of the drawer attaches to the main body of the drawer you can carefully unclip it. Once the front is removed you can safely put the rest of the drawer in a dishwasher to help kill off the remaining biofilm traces. I've done this thousands of times with Bosch/Siemens and AEG machines without any problems.
Clean the drawer regularly to prevent re-occurrence. You may also wish to consider switching to a wash powder brand with built-in conditioner, such as Bold: if you don't need to put conditioner into the dispenser, there's nothing for the biofilms to feed upon. They will feed on powder residues though so although you'll reduce the likelihood of getting further blockages you'll still need to clean the drawer (and the aperture it fits into) regularly to ensure that it never occurs again.
Please ask any questions if my solution is unclear, but if I've answered your question satisfactorily then please take a moment to rate my answer.
Posted on Jul 15, 2010
Fabric dispenser leaves water in dispenser after wash is done
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Jan 16, 2016 | Washing Machines
Water in the Softerner compartment
The softener drawer cover is designed to siphon out most of the water that runs into the drawer so, when the wash is over, the drawer should always be nearly empty. Unclip and take out the detergent drawer, unclip the softener cover and fill the softener tray with water. Clip the softener cover back on and the water should run out immediately. If it doesn't then a small blockage in any of the 3 pipes in the cover can completely stop the siphon action. Cleaning them out is generally all that's needed.
Apr 06, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
On the AWZ 410 washing machine how do I remove the washing liquid drawer.
if you pull the draw as far as you can there is a bit at the back of the draw to press down on and then the draw will come out
Nov 20, 2011 | Washing Machines
I have an indesit 1100 washing machine, but it does not take the softener in from the draw. i have cleaned the draw out nad tested the draw over the sink. it seems to work ok but once its back in the...
You need to clean the drawer box top, the holes get blocked and the pressure is only low on the conditioner section..you will need a lengthy object to clean the hole properly
Oct 05, 2017 | Indesit Washing Machines
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Mar 30, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My fabric softner draw on my meile washing machine is filling with water and not draining properly. what is the problem
take out the drawer and clean the fabric softener compartment, sometimes this gets clogged up and just needs a good run under the tap
Jun 06, 2009 | Miele W865 Front Load Washer
The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
Nov 15, 2008 | Washing Machines
Maytag Washing Machine
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Sep 06, 2007 | Washing Machines
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
353 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
