Question about Sony VAIO Digital Studio PCV-RX650 PC Desktop
Took the cover off to clean the dust off the fans put it back together it will turn on and fans will run but wont boot
  • Sony Master
  • 5,660 Answers
1) Side Cover off; Observe whether the fan that pushed air over the Processor is operating.
2) Remove all ram memory modules, and reseat them.
Doesn't take much to bump a ram memory module ('Stick') loose.
Although they may appear to be correctly seated in the their individual ram slots, it is just added assurance to remove, and replace them.
3) Computer was unplugged from power, and if you reached inside, you did observe Anti-Static Precautions, correct?
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit), the delicate hardware components inside a computer.
You must relieve your body of Static BEFORE, reaching inside your computer.
Computer unplugged from power, Touch the metal frame of the open computer case, to relieve your body of Static.
As also has been stated, make sure all cables all plugged in tightly.
This is Sony eSupport > Vaio PCV-RX650 desktop computer >
http://esupport.sony.com/US/perl/model-home.pl?mdl=PCV-RX650&region_id=1
Left-click on Manuals, Specs, Warranty
Under the Manuals heading, left-click on System Reference Manual
Posted on Jul 15, 2010
  • joecoolvette
    joecoolvette Jul 17, 2010
    Your rating is appreciated!
    Statement,
    "1) Side Cover off; Observe whether the fan that pushed air over the Processor is
    operating.",
    is supposed to read,
    "1) Side Cover off; Observe whether the fan that pusheS air over the Processor is
    operating"
    President:
  • 2,571 Answers
Take the cover back off, remove and refit all the power and data cables 1 by, you may have disturbed 1 without knowing.also check data cable connection to the motherboard.
When you refit the cover, make sure it on securly and fully. Some cases have anti tamper switches and wont boot if the case is loose.
If it still wont book get back in touch and we can try something else
I took the filter out of my Windtnnel Pro Pet to clean it (not with water) I put it back in and now the vacuum wont turn on.
I'm going to guess that when you put it back together it didn't quite go back in correctly. There could be a switch that prevents it from turning on if the filter is not installed. Make sure that it is seated correctly. I hope thats all it is.
Dec 27, 2014 | Tti Hoover 4010100Y 3-Pack Type Y...
Why wont my asus a6000 wont power on. I took it apart and put it back together again and now it wont do anything cept the green light and the hardrive spinning. No fan and no screen activity.... Pleas
Sounds like it might have booted up especially when you say after 20 minutes the fan turned on. Maybe everything booted up and is running except your screen is black. You might have disconnected the LCD Cable when you pried the touchpad up to blow out dust. Try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 01, 2012 | Computers & Internet
Hi, we have a roland camm-1 cutter plotter. It has been showing "fan error" on the display these last few days but would correct itself when turned off and on again. Now though,when I put vinyl in and send...
I had a similar problem. The issue was that I would receive a "fan error" notice but the fan was still spinning when the error displayed and then the machine would stop. I took plotter to my garage, removed the covers and used my air compressor to blow out the dust from the fan and the circuit boards. When I blew out the fan, a ton of dust and "dots" from the punched material came flying out. After a thorough cleaning, I put it back together and have not had the problem since - it works like new. I think what happens is that the fan becomes clogged with dust and dots and slows the fan enough to send an error signal to the plotter. No dust, no dots, no error! Try that - hope it works for you!
Sep 16, 2010 | Computers & Internet
Fan runs loud,constant on HP a1620n
cheek the cable of cable properly plug in
R
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
R
cheek out fan for electric shot
repaly me if i solve your problem
Dec 13, 2008 | HP Pavilion a1620n (882780664494) PC...
My screen is black!
There is a boot problem, maybe. I think you have accidentally disconnected the screen or the RAM module cables. Be sure of what you're doing before opening up a laptop.
Search online for the process of fixing this by reconnecting the cables. Or maybe, you have to get a doctor if you can't do it yourself.
Nov 22, 2008 | HP Pavillion ZV6000 Notebook
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Trouble booting after cleaning
Try unplugging the dust on the cpu grooves under the cpu fan.
Hope it helps
Nov 22, 2007 | Abit A17 Guru Motherboard
Overheating?
Hey,
I think it's the cooling... Because when i let it cool down after it shuts down for like a few minutes I can boot it back up. But if i try to boot it up right after it shuts down it won't let me. I think it has a built in temperature monitor to make sure it doesn't overheat. I'm going to install some computer fans on the vents of the projector to get some more airflow. Hopefully that will do the trick.
Nov 03, 2007 | CTX Optoma EzPro 680 Multimedia Projector
Sony VAIO Digital Studio PCV-RX650 PC Desktop Logo
136 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
