Question about HP PSC 1315 All-In-One InkJet Printer
Doesnt seem to work
It just turns on and do nothing.. doesnt print, copy or scan.. when i turn it on its just it.. tks, hope u can help.
  • Anonymous Apr 28, 2008
    After 3yrs the cpu was formatted and reloaded but when the hp psc 1315 printer original cd was loaded. It goes through all the phases but when it reaches 96% on the installation(Last item # 4), it just gives up. every time the cpu is switched on it goes thru the installation phase but with the same result. Pasha
    Scholar:
  • 57 Answers
Do you have your printer connected by a USB port? Do you have several USB items on your system? (Printer, mouse, keyboard, etc etc) It is possible that your USB ports are overloaded and cannot process the information. That's what the USB hubs are for - those little ports that you can get for as cheaply as five bucks some places, up to big bucks for the heavy duty ones.... you can plug up to four USB items into the hub, then only ONE USB plug goes into your processor.
I am really not sure if that is the problem for you, but worth a try. Also, it is possible that the USB port you have it in is wearing out - try another one if your machine has them available. They do die.... if it powers up, it is likely that the port isn't dead, so I am thinking that it is just too much for your machine to process, and it is ignoring all other requests to that port.
(PS - when the 1315 dies, it is not worth resuscitating! It isn't HP's finest moment, and was their earlier attempt at an all-in-one. I found it to be more hassles than it was worth!)
Posted on Jun 12, 2008
Why-print-comes-all-black-all-over-paper/
Check the scanning lamp, when copying see if the scanning is not working,,it should be turn on when copying, if yes, then replace the scanning lamp, or drum unit, drum unit have certain life span or copying yield about 100 to 300 thousand copies produces. Check your counter reader in your machine. If yes, then replace drum unit, hope it help.....
Jun 15, 2014 | Kyocera Mita Office Equipment & Supplies
Printing blank page
Open the top and make sure the carrier is not stuck to one side and also check that the drive belt is on.
Jan 27, 2014 | Canon PIXMA MP600 all-In-One InkJet...
Won't scan but prints and copies
turn off computer. turn on - does a test page print? You need to unplug the USB cable from the printer and put the test page on the scanner - push scan. This should scan the page. Turn off computer, hook USB back up. Try to scan whatever you are scanning.
Hope that helps!
Apr 20, 2010 | Dell 924 All-in-One InkJet Printer
Can scan & copy, but can't print
It may not be the settings, it could be an outdated driver, if you are using the cd too install software, try downloading the software from hp website.
Feb 07, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
X6150 Copy problems
Had exactly the same problem. Solved by turning copier on, then unplugging it for 30 seconds..plug back in...Problem solved.
Mar 21, 2008 | Lexmark X6150 All-In-One InkJet Printer
Can't get the printer to print
Cycle power including unplugging AC cord from printer.
If you cannot copy (scan) after power on, the printer is bad.
You should be able to copy (scan) after printer is turned on and initializes (It will say "COPY / 100%").
Feb 18, 2008 | HP PSC 2110 Color Printer
E4 error
if you are using refilled cartridges, remove the cartrigdes, switch printer off anf then on. reinstall the cartridges and give a copy or scan
Sep 13, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
Ben Johnson
