Question about Refrigerators
Do you have any information about a SAECO WP110 Top Water Chiller ? We have three of them. One is O.K. One doesn;t work and one the water tastes bad.
SOURCE: Bad water & ice cube taste
We have the same problem; it started when we moved to a house with well water. Now we buy ice and dump it in the ice maker and drink bottled water. All this money for a side by side with water and ice despenser for nothing! We also have front loader washer smell. Is it well water? I miss the city...
Posted on Jun 23, 2008
  • 399 Answers
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Posted on Sep 16, 2008
SOURCE: ADMIRAL FRIDGE MODEL AS22N8DE WATER AND ICE TASTE BAD
change water line into refrigerator Alge will start to grow, also flush line into refrigeratorwith a little bleach to kill any alge in the line. It will take a while to get bleach
Posted on Sep 26, 2008
huuum
  • 750 Answers
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
Arius
  • 446 Answers
SOURCE: Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Posted on Nov 27, 2008
The water and ice started tasting very bad with a sulfur chemical taste a few months after the water filter was replaced. What should I do?
Did you recently have a water main break in your area about the time the bad taste started or any plumbing repairs in the house?? Could be the filter is contaminated. Try another filter and go from there. If problem is gone it was the filter. If still there---possible problem with refrigerator water system and tubing.
Mar 15, 2015 | Whirlpool ED5LHAXW Side by Side...
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Descaling the machine
When you have deccaled the machine just let water through two or three times. Then there should not be any extra taste of the coffee. Good luck Kolbrun
Nov 23, 2013 | Saeco Odea Go
Hi! One of my friends has an old Vienna Digital coffee maker (Saeco). It works fine. The only problem she has is that her coffee is never hot enough. She has to put her cup into the microwave if she...
There is a thermostat that is stuck on the boiler. I would suspect that this thermostat has either:
1- A bad contact with the boiler. Contact is assured by thermal paste
2- The thermostat is faulty and gives false readings, thus preventing the boiler to heat the water enough.
Hope this helps
Apr 09, 2011 | Saeco Vienna Digital Coffee Maker,...
I put milk in the water tank.
Well, it's not a good thing. Before I offer my opinion, I always encourage anyone to contact Saeco directly, since this is a heavy-duty mahcine. That being said:
Because milk contains calcium, you are going to need to thoroughly decalcify your espresso maker:
Pour distilled white vinegar instead of water into the water reservoir. The vinegar is going to run thorugh the system slower than water, because it is thicker. You may need to run three cycles of vinegar to get all of those calcium deposits out. If the vinegar is not effective, you may use CLR - but make absolutely sure that CLR is non-toxic when ingested. Run two cycles of water through the machine - filtered water if you can spare it - after you have finished the vinegar cleaning.
-Tha Mp3 Doctor
Mar 20, 2009 | Saeco Royal Professional Espresso Machine
Saeco Aroma now only produce bitter coffee...
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Feb 03, 2009 | Saeco Aroma Espresso Machine
Hello redwood City
Welcome
You said,
copper tubing."
Whirlpool remedy
Thank You ,
HUUUM!!
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Burned taste
Descaling often removes bad tastes and smells.
To order descaler or Saeco parts for your espresso machine please visit www.cerinicoffee.com
Dec 12, 2007 | Saeco Classico Espresso Machine
Water problem
if the lines are plastic then it has to do with your water supply line. is the supply a saddle type valve in your basement and is it connected to a copper pipe or a galvanized steel pipe?
Apr 30, 2007 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
