AOC 2436Swa LCD screen controls
I have an AOC 2436Swa LCD screen and when using the TV via Windows 7 Media Centre I cannot find out how to change the screen aspect ratio to make the TV signal fill the whole screen. I have tried the toch controls on the bottom right edge of the screen but cannot figure out what the symbols mean or how they work. Is there a user manual available?
SOURCE: Aspect Ratio not responding/always in "Full" mode
i have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
Posted on Apr 22, 2007
elecgooroo
  • 57 Answers
SOURCE: heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Posted on Dec 10, 2007
skotkolr
  • 558 Answers
SOURCE: aspect ratio
display setting
from the desk top right click and select properties, then select the settings tab then change your screen resolution display setting
Posted on May 08, 2008
SOURCE: 22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Posted on Apr 28, 2009
  • 3 Answers
SOURCE: LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Posted on May 17, 2009
How to fix AOC LCD TV random vertical coloured lines, no response to controls
Sounds like a screen fault. The adhesive that attaches ribbon cables from the drive electronics to the screen has failed. Unfortnately this isn't fixable because the connection and spacing is too fine to get a 100% reliable connection. Some DIYers have used neoprene rubber tubing as wedges to hold the connections in place. That actually works. Search Youtube
Sep 07, 2014 | AOC Televison & Video
LCD AOC 2436Swa is stuck on active-off mode
tried to unplug the unit and don,t use for a while to reset the power supply as will as the main board.
Jan 08, 2013 | AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms -...
My monitor has turned vertical
go to monitor setting in display and click rotate .. this should fix the problem.
Sep 10, 2012 | AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms -...
How do i enlarge the print on the screen
there are several things you can do, change the screen resolution, or change the size of the text, to do this go to Control Panel - Appearance and Personalization - Display then click the 125% radio button and apply. in versions of windows older than windows 7, this process may be slightly different, this option may be in the ease of access centre. if you have trouble changing either of these things type your operating system and change screen resolution or change text size into google. to change the screen resolution go to control panel and in appearance and personalisation click adjust screen resolution, this will make everything look bigger, try to keep near the same aspect ratio or photos and text will look distorted or stretched.
Mar 14, 2011 | AOC Computers & Internet
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
AOC Plasma TV turns on by itself and changes channels non stop.
I have an AOC 32" LCD HDTV and it turns on by itself as well. Tuning is done via my cable box, so the tv is set on HDMI and I don't have the channel changing issue. I as well am trying to figure it out. The only thing I could suggest is perhaps the remote batteries are low and triggering on it's own. Try changing the batteries, or ensure that the remove it in a drawer or other room so that triggering the unit is impossible. Hope that helps.
Jun 17, 2009 | AOC A42HD84 42 in. Plasma HDTV
AHitachi 26LD6600 connected to Radeon 9550 graphics card using a DVI to HDMI cable
The Hitachi's native resolution is 1024x768. It won't properly display above these resolutions via VGA. You might have more luck via HDMI but I doubt it.
Aug 26, 2007 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Computers & Internet Logo
256 people viewed this question
Alun Cox
David Payne
David Payne
