Question about Toshiba e-Studio 161 Copier Copier
Hello! On the control panel of my Toshiba studio 161, there is a picture of the photo copier containing 4 symbols....the second of these is flashing red. HELP PLEASE!
    President:
  • 2,072 Answers
Either the toner is empty or the drum unit needs replaced.
Posted on Jul 15, 2010
How to reset Toshiba e-Studio 161 Copier Copier with "error code H4"
Step 1:-
Press
"C" key AUTO/TEXT/PHOTO key
"C" key AUTO/TEXT/PHOTO Key
(Note:Perform the first two key strokes quickly )
Machine display should stop blinking
Now press 14 and press start button.
Switch off and on to check
Feb 27, 2016 | Toshiba Office Equipment & Supplies
I waint to know how to inter sim 14 for toshiba photo copy m/c model e-studio 161
Hi Wahdain,
Its so simple enter the formula given below. First press the C button then press the exposure mode change button ( this is what you used to change the exposure from auto to manual or photo modes) then again C button, then again exposure mode change button then 1 and 4 then start button ( this is what you press to take a copy) Try this and put it right.
Best Regards,
Rakshita
Jul 07, 2011 | Toshiba e-Studio 161 Copier Copier
Estudio 161 4h error code
h4 low heat from heater unit do the following [c key]-[auto/text/photo key]-[c key]-[auto/text/photo key] machine will go dead key in 14 press print machine will cycle if the error code returns you will have to replace thermistors and thermofuse
Mar 19, 2011 | Toshiba E-Studio 161 Copier
I have H2 flashing on my Toshiba e-studio 161 copier
h2 error is the fuser unit is faulty check and replace heater lamp thermo fuse and thermistor
Mar 07, 2011 | Toshiba e-Studio 161 Copier Copier
TOSHIBA E-STUDIO 161 error code show mw H and 4
How are you this is jack my id jack_pak@hotmail.com
your copier toshiba 161 show H...4
Dear, Follow the procedure.... press C(CLEAR) BUTON+ PHOTO BUTON+C BUTON+PHOTO BUTON..... Your copier enter special mode
Then you press 14 and start key.... copier ...ok
PLEASE VOTE ME
Thanks,
Best Regards,
Aug 31, 2010 | Toshiba e-Studio 161 Copier Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
Can't print or copy with my toshiba e studio 161
H2 indicates thermistor open.
U can enter simulation mode and input "14" to clear the message.
If happen again, u need to check following:
Thermistor
Control PWB
Fusing section connector disconnection
The fusing unit is not installed.
Perform the following procedure to enter the simulation mode.
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
Jan 15, 2009 | Toshiba e-Studio 161 Copier Copier
E studio 161 ink indicator
Dear sir; First I have let you know the copier use toner not ink , want to know how many left over; 1, press and hold down the left exposure key until indicator flash, then press and hold the "%" key for 5 seconds.the window will show out the percentage. LO means less than 10%, press left exposure key to escape.if there still have problem please let me know, otherwise please be generously give me rating. thank you. HAVE A MERRY CHRISTMAS !!!
Dec 24, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba estudio 161 copier
1. Entering the simulation mode
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-Studio 161 Copier Copier Logo
96 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
