Question about Asrock P4I45GV R5 Motherboard
No display but the cpu fan is blowing (running) no beep
  • 621 Answers
Ive had a lot of reapair jobs with that motherboard and everytime it has turned out to be a blown motherboard. Test the memory first by trying just 1 stick at a time and if you wish to replace the motherboard do NOT buy the same model. Cheers from Scott please dont forget to vote
Posted on Jul 15, 2010
Dell VOSTRO 460 beeps during startup and will not startup.
many times if the fan over the cpu chip on the motherboard fails to run or blow, an beeping alarm will begin and PC will not start. the cpu has to be kept cool so if fan fails the startup is stopped. have found lose wire connections from fan to motherboard terminal, or power supply may be blown, try checking those first. if nothing lose then wiggle those wires to see if the fan starts.
Jan 30, 2014 | Dell XPS 200 PC Desktop
Does not boot, no beep, no display, fans running on high speed
Try blowing the dust out of the inside, around the vents, around the fans and by the cpu and heat sink.
Also remove the fan as it sits on the cpu and heat sink. Then remove the heat sink that sits on the cpu, then remove the cpu by releasing the latch on the side of the bay it sits in (remember how the cpu goes back into the bay). Now clean off the old dried up thermal paste on top of the cpu and on the heat sink that sits on the cpu. Put the cpu back into the bay and secure the latch. Apply a fresh coat of Thermal Paste to the CPU and Heat Sink. Put everything back together then reboot.
If the thermal paste has dried or is too thin to keep the unit cool it's like metal touching metal and shorts out the system so it can't boot.
May 31, 2012 | Computers & Internet
Toshiba satellite m305d power light on fan runs for 2 seconds shuts off no screen
Either your motherboard, CPU, or GPU have fried. You can try to re-seat your ram but if there is no beep/beeps and nothing but a power light, and fan running for a couple seconds those are the only options. If your handy you might get lucky and get it to work for a little (as long as you have thermal paste) Remove heatsink, & fan, then the CPU blow out the connections with compressed air (to go the extra mile electronic cleaner) then let dry for a few hours reassemble, hoping for the best the whole time mind you.
Jun 21, 2011 | Toshiba Satellite A135 Notebook
No Beep no display: Cpu fan Running.
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Dec 29, 2010 | ASUS P4VP-MX Motherboard
Power on but no display processor fan running power switch light off
Power light possible means nothing, maybe a burned out led.
No display: Try feeling the cpu heatsink to see if its getting warm. If it is cold after 15 minutes running, the CPU may have failed. If warm, move onto the graphics. If using onboard, try using an aGP card and see if you get a display then.
(I'm assuming that you get a beep on powering up? If you get no beeps at all, confirms CPU is at fault, if 8 beeps on start up, probably graphics. any other beep codes, post them and I (or somebody else will help)
Dec 28, 2010 | PC Chips : PC-Chips M909G P4 /FSB...
My computer system after turning on, turned off. cpu fan on and then off. mobo led is green (p4b533 asus). power is good, and unpluged all devices but no change! is cpu dead?
your cpu is probably overheating
turn off the power and unplug the computer and all periferals.
it may be dirty or the cpu fan may be going out. open the case, clean the fan with a can of air and cotton swabs. do not allow the fan blades to rotate freely when blowing them with air by holding them in place (or the bearing may go bad). you may also want to blow out the rest of the case as well and remove each card to clean them with swabs and air.
it will be slow work, but it can save you wear and tear on the entire system by doing so.
put everything back together and try everything to see that they work properly. if the problem persists, you may need to replace the cpu fan or risk damage to the processor.
Dec 02, 2008 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Jun 14, 2008 | ASUS P4P800-X Pentium Motherboard
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
May 17, 2008 | E-Machines eMachines Desktop PC
Asrock P4I45GV R5 Motherboard Logo
129 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
