Question about Reliance & 40 Gal Mobile Home Water Heater
Sir, my reliance gsm sim stop . the sim less on the park name - anju devi mo. no. 8103787910
I have a Reliance 501 electric water heater ... Everything works great but below the water out. Be rusty? How can I fix it?
The tank is rusting. Replace anode rod or replace water heater.
Once the anode rod depletes, then the tank starts to rust.
IF you can replace the anode rod, it will stop rusting, and then flush the rust out of water heater.
This might buy more life with same tank, but old anode rods are pretty solid and even impact wrench might not loosen it up.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Loosen anode rod on new tank before installing, and then inspect every 1-3 years, and 1-2 years if water is softened.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | RELIANCE ELECTRIC WATER HEATER
I cant seem to find were the gallon size is on my reliance 501 electric water heater were might it be located?
Look at label on side of tank.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Other useful links:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Mar 25, 2011 | RELIANCE ELECTRIC WATER HEATER
Can you email me parts diagram and numbers for Model 63070RT, Serial number 1047A009171.
I don't see that manual at Reliance and am unsure if this is gas or electric heater.
Contact Reliance directly:
http://www.reliancewaterheaters.com/prod/gas.html
http://www.reliancewaterheaters.com/contact.html
Find age of water heater:
For a price, expert works with you via e-mail or phone while you work on water heater or any do-it-yourself project.
Feb 23, 2011 | Reliance & 30 Gal LP Gas Water Heater
Trying to find temp dail
You posted under Reliance point of use electric water heater.
Open following link to access manuals:
http://www.reliancewaterheaters.com/lit/om/e100.html
Thermostat has adjustment screw.
Open access door on side of water heater
See diagram of thermostat and approx settings:
All water heater temperature settings are approximate.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#Reliance
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Feb 19, 2011 | Reliance & Electric Water Heater
How can i get PUK code of reliance sim my no. is 9827311728
You posted under Reliance water heaters, so question comes to hardware section.
Re-post question under cell phones.
Feb 15, 2011 | Reliance & 40 Gal Mobile Home Water Heater...
I have a reliance model 501 electric water heater thats 8 yrs old who's responsible if it blows out the thermostat and floods the bldg I'am on the third floor codo
The person who owns the water heater is usually the responsible party. If it is in warranty, I have heard lately that serveral of the insurance companies have sued the manufacter and won but this is rare at this time. If unit is working I would put some type of preventive measure to stop if from drowning the people below and ruing your condo too.
Water Cop'
Brust Buster
Watts water stop
this is just to name a few to protect yourself and other under you.
Oct 04, 2010 | RELIANCE ELECTRIC WATER HEATER
How do we know if our hot water heater is under warrenty?
Hello,Look at the info sticker for a manuafactuer date/year.If it's less than 6yrs. the TANK is under warranty.
Sep 27, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a reliance 606 electric water heater. it heats water fine when its on...it keeps tripping the circuit in the breaker box though...How do I fix this? thank you!
Open covers on tank and inspect for burned connections or melted parts
1) Test electricity to water heater:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
2) Test water heater elements
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Aug 31, 2010 | RELIANCE ELECTRIC WATER HEATER
Friend took wirers off top thrmostate need to know wiring diagram for reliance model # 540Z0RS1 4500 watt volt240
How to wire thermostats
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
May 10, 2010 | RELIANCE ELECTRIC WATER HEATER
Waht is the PUK code for reliance mobile sim
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it.Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account.It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone.If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, You need to go to your Service providers, web site & navigate your way to the specific PUK details for your mobile phone network operator. Usually you have to Register your phone to get a PUK code.
Apr 26, 2010 | Reliance & 40 Gal Mobile Home Water Heater...
Reliance & 40 Gal Mobile Home Water Heater  Logo
42 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
