Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool Cabrio top load washer is flashiing dl and after initiating the cycle shuts itself down. Isaw from another post that this is a door lock issue but what do I do to fix it?
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Im getting a code of dl when i start it up...than it just peeps and nothing else happens
dl means door lock error you have to replace the door lock switch cheapest supplier might be marconeappliance parts
Aug 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Problem code? dL?
DL= Door Lock...you must have a problem with the door lock. Good Luck, I hope this helped
Dec 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting a DL on the top load washer
The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DL indicates a problem with the door lock mechanism. See the section on troubleshooting and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
CABRIO WASHER
DL or F 83 is a door lock issue. Make sure the light is off before opening the lid and also check where the lock is for build up a gunk.
Aug 03, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal De
