Turning "on" results in clicking noice off and on and then eventually turns on. Got worse over a week to poin it will not turn on. Also had audio probelms a few times when it did start.
  • Televison & ... Master
  • 17,130 Answers
You must have a shorting in the circuit which was coming on at times and has now full done. Unfortunately if if had been checked earleir maybe we could have found a bettter solution. Since the set is not poweering on now, you will have to open on the set and check for failure of the drive output. Check for dry / poor joints if so solder and go forward. if not check for fault on the transformer or the output. look on the power circuit for the same faulty connections.hope this helps, good day
Posted on Jul 15, 2010
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
Thumping noise while driving left side worse when turning right
have you had it balanced and the driveshaft looked at? id start there
Jun 09, 2012 | 2001 Chevrolet Blazer
Creative Gigaworks T20 (series I) Left speaker just producing noice, until I turn the Bass knob counterclockwise towards "minus" - then there is sound in the left speaker but even more noice...
The problem that developed with my Creative Gigaworks and other is that occasionally it would not play at all. When the problem occurred, I could eventually get it to work again by turning it on and off several times. I opened up the powered unit (the Right speaker with the controls and found that the wires were really crammed in there, such that a white ribbon wire connector on the bottom was straining to the point of where it was slightly cracked. While playing audio through it, if I touched that wire ribbon, the sound would cut out. So I adjusted the wires slightly to relieve any tension force on that connector and it has not had the problem since. I would open up that unit and check for a similar poor or strained connection. To open the unit, carefully pull off the fabric speaker cover straight off, remove the 4 rubber inserts in the top 4 holes, and remove all 6 philips-head screws in those deeply recessed holes.
Jun 03, 2011 | Creative Labs GigaWorks T20 Computer...
How do you tell if a starter is going bad
The starter will drag and not turn the engine over very fast. The starter solenoid is part of the starter also. It will just click a few times before it starts turning the engine over if it is going bad. It will steadily get worse. You will have to click the starter solenoid several times before it will start after several times. Eventually it will not engage the starter.
If this helps please rate by clicking the 4 thumbs ups. Thanks!
Jan 19, 2011 | 1994 Pontiac Grand Am
It makes a loud noise when i turn and shakes and thumps driving, when i push the gas it gets worse and makes awful noises the whole time i am driving.................i had the wheel baron replaced last...
does it click click click when turning or pop pop pop either-or the rack and pinion steering may be bad.or just a u-joint on the steering rod
Aug 13, 2010 | 2000 Nissan Maxima
The wheels sound as if they will fall off on passenger side front wheel, ABS light goes on/off intermittently. Worse when turning to the right-actual rumbles so loud. frustrating when paying $1,500 for...
im guessing by the sounds of your discription that its a wheel bearing, and that would make the rimbling noice , ive had one go on me before and that is what it sounds like
Feb 27, 2010 | 1991 Mercedes-Benz 190
Started with occasional click sound when I turned the key but would eventually start. Problem got worse and worse and now I do not even hear a click anymore. Replaced the starter and cylinoide and still...
Likely it is a bad relay. would have been easier to find when it was clicking but usually it's located with a group of other relays in a power distribution box.(under the hood)
Aug 25, 2009 | Dodge Stealth Cars & Trucks
BOOM SOUND AT AUDIO MODE CHANGE
Suggest turning the volume down on the Receiver/Amp before changing modes. Changing modes can produce signals that can hurt speakers if driving at mid-high levels.
Regarding the sub, turn off the receiver first, then turn off the sub. When turning everything on, turn on the sub first, then the receiver. If you still hear the noice in the sub, turn down the volume in the sub before turning it off (making note of what volume level you prefer for it when it is on).
Oct 26, 2007 | Denon AVR-2500 Receiver
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Open Questions:
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
