Question about Refrigerators
Meile f/f not working advice get a new f/f cant afford to do that
Meile f/freezer not working comp very hot capacitor problem ?
rang meile UK who would not tell me if there was a capacitor, or if there was where it was located recommended service call !!
meile fridge freezer no visible capacitor but when external one is attatched the comp runs so is there one inside the cabinet lining if so this seems an incredibly stupid place for it
model no is KT3534sed
comp is aspera NBT1118Y R600a
Fan is not working
T-stat issue is most probubal. Or check the condenser and clean it if needed. Or if comp runs then stops then runs then stops and or very hot, your comp is shot and needs to be replaced,
Apr 01, 2014 | True Freezers
Curcuit daigram
Please check on the link below for a good visual description of the fridge parts:
click this link:
For a visual description., click on:
Aug 17, 2011 | Refrigerators
At first i smelt a burning smell then found the fuse had blown,i replaced the fuse and worked for a while then the motor was geting hot and the fridge wouldnt stay cold
it means your compressor hi pressure cause of blown fuse check the condenser fan if running ok if not replace capacitor or lubricate main shaft. then observe your comp. if working continues.
Feb 19, 2011 | Engel 43 Qt.Portable Freezer.
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
The fan on my fridge is working, but its not cold. Everything thawed out. Do you know wht this could be?
There are a couple things to check and do.. 1st check if your compressor is hot.. (pull fridge out, back bottom area remove to get to comp) if comp is hot possible refrigerate leak.. the other is capacitor (or hard start kit is needed)... unplug fridge and let sit for a few hours (like 5hrs).. plug back in.. you should feel cloud in the freezer area in 15min.. if not then, your possible problems I mention 1st.. hope that well do.. good luck.. mike
Jan 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer works, fridge doesn't
freezer ok no refrig???? do you here a fan on in the freezer sect when you open the freezer door?? common problem to have a bad evap fan motor and the unit will not blow the air up to the refrig compartment
Oct 27, 2008 | Maytag MBF2256H Bottom Freezer...
Fan is working on fridge, temperature is set correctly but fridge not cooling. the compressor boiling hot.
is the compressor fan working and the freezer fan working also? if you have a meter you can do a amp draw on the comp.,it sounds like the comp. being so hot your coils under the frig. are real dirty or the comp is about to lra out(burn out) let me know more-mike
Oct 21, 2008 | Refrigerators
Freezer not freezing
Check your temperature setting.
Feb 04, 2008 | Electrolux ER7926B Bottom Freezer...
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
