Question about Kenmore 24032\24036 Top Load Washer
I am working on a Kenmore Oasis washer, model
I am working on a Kenmore Oasis washer model 110-27062603 which fills a little then code F-50 comes up and it will not run. I can cancel and drain water. I read through diagnostics-found no reading on wires to rps. I checked motor windings & they were ok. I then replaced the rps assembly but still have the same problem. I did notice that the stator housing was cracked but not broken. Any help would be appreciated.
  • 15,935 Answers
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#@
Posted on Sep 30, 2010
I am working on a Kenmore Oasis washer model 110-27062603 which fills a little then code F-50 comes up and it will not run. I can cancel and drain water. I read through diagnostics-found no reading on...
Jun 23, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore elite oasis washer model # 110.2703 shows code F-50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Need to know what 50 means --washer keeps beeping after tub fills
Please see the following Whirlpool Service Manual for their Cabrio Washer (Basically the same as the Kenmore Oasis)
50 points to an obstruction keeping the basket drum from turning freely.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Nov 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer LF code sears kenmore 80 series
It means that your machine is taking longer then a specified time (~10 Mins) to fill!! Check your water pressure, the water valves, the little filters in the hose, where it screws into the water and/or machine. Good Luck
Aug 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Kenmore oasis washer F50 error
I understand your frustration, error codes F 50 and F 2 run hand in hand. This is an error having to do with the main control board not communicating with the ccu. Usually F 2 is the control board straight up failing and F 50 can also mean the ccu is not understanding what is being said. The parts are usually 200 plus and with this error the ccu is probably part of the solution.
You can tell by this;
Control board is shot if: comes on by itself, changes spin speed even during wash, wash time freezing, beeping while all of this is going on and on occasion powering up to start a rinse cycle long after your done.
The ccu is harder to diagnose, usually erratic wash cycles of extreme imbalance ul error codes or over filling.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27062600 Fault code 50
Any solution? I have the same F50 error code.
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
101 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
