Question about Dell Latitude E5400 Notebook
Got my lan port damaged.... one of the internal pins in the lan port came out.. what to do?
    Guru:
  • 366 Answers
You need to contact the Customer Service please as they need to check how the LAN port is fused on to the mother board and then advice accordingly.
Hope it helps.
Posted on Jul 15, 2010
    Master:
  • 515 Answers
If it is not working now, you may like to bring the laptop to the reseller or the manufacturer if it is under warranty. LAN port on your laptop Ethernet card is a little hard to fix. If you like DIY, you can unpack your laptop (by unscrew it all and disconnect ribbons and plugs just like the manual or youtube video said, pay attention to the rubber stands which may cover some screws and the little clips you can press to pop up the keyboard or the edge) and see whether ther Ethernet card is not integrated to the mother board so you can replace it with an identical one (ebay, staple, local computer store, etc.).
The LAN light does not come on the router I have unplugged, reset, what else can I do please ?
Router has switch port to connect pc.is there problem,pls check the lan cable. also connect another cable.
clean the lan port ans clean all pins
Sep 12, 2017 | The Computers & Internet
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
My printer have a problems in lan and usb card has damage
hi,
if the lan port is damage and the usb port is damaged, there no way to use it to connect unless the lan port is on a slide in card and the same for the usb port,
You may be able to buy a card with will replace the damaged one, I have seen similar items on ebay.
Regards
GeWiz.
Dec 21, 2009 | HP LaserJet P2015dn Printer
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Apr 30, 2008 | Computers & Internet
Sara
First of all, you said "routers", do you mean yo have more than one?
Your router has one "external" or "internet" port, and one or more "internal" or "network" or "LAN" ports. If you have wireless it is "internal" too.
Your Internet modem should connect to the "external" port only.
The computers and other home devices go to the internal LAN ports. If you have a separate hub/switch they are connected to, the switch itself should connect to the "internal"
If it doesn't run by default you'll have to follow the Quickstart instructions given with your router.
Note: if you have wireless, you SHOULD setup your router as per instructions, because by default anyone close to your router can connect to it.
Jan 09, 2008 | Computers & Internet
Dell Latitude E5400 Notebook Logo
215 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
