Question about Dell 725 InkJet Printer
My Dell 725 Printer driver says it has been installed successfully but the printer is not showing up in the Control Panel and therefore I can't print to it...any suggestions of how to fix this?
    Guru:
  • 528 Answers
Hi. May i know what Windows version are you using. Have you tried running a print test page since your successfully installed DELL program.
Posted on Jul 15, 2010
  • jeff_kimbell Jul 15, 2010
    I am running Windows Vista on a Dell Inspiron 1520 and trying to make a Dell 725 printer work. When I plug the USB cable from the printer into the computer a popup window says windows is installing the driver then it says it was successfully installed but when i then go to the control panel/printers page the printer isn't listed as a printer i can select
  • Archie Cruz
    Archie Cruz Jul 15, 2010
    I see. Windows vista is tryin to install the best driver he can use inorder for the printer to work . But this is not 100% guarantee if this driver used by VIsta will able to drive your printer. Best thing to do is install the CD driver that came with the printer when you purchased it. I have provided you a link where to download your printer driver if incase you misplaced the driver disk. Please click here.
    All the best!
725 printer prints constanty on its own when not called for
If it's printing jibberish or "ASCII Garbage" then you probably have the wrong print driver installed.
Uninstall the print driver, disconnect the printer, reboot and reinstall the driver plugging the printer back into the PC when the installation software prompts you to.
Mar 12, 2011 | Dell 725 InkJet Printer
I disconnected the printer from the tower for computer service with a local vendor(blue screen). Repair completed. When I reconnected the printer, I discovered that I was unable to print documents from the...
Open Control Panel, Printers and faxes. Check if there is icon for your printer. If not, you have to install the driver using CD that comes with the printer.
Blue screen often means very badly broken windows installation and your vendor probably reinstalled it as new installation. Therefore your printer may not be installed.
Jun 15, 2010 | Dell 924 All-in-One InkJet Printer
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
May 27, 2010 | Dell 725 InkJet Printer
Green light flashing
Do the following.
Remove printer cartridges. Disconnect printer USB cable. Disconnect printer power cord. Inspect printer looking for stuck paper or foreign objects inside printer. Clean the printer contacts to cartridge inside the ink carriage. On computer go to Control Panel >Printers and delete the printer from control panel. Reinstall printer driver. Connect the printer USB to computer when prompted by printer driver setup process. After connecting the printer refit cartridges, load paper and try printing again.
If that does not fix the problem, then there may be a fault.
In that case try ringing Dell support at the number listed on the owner manual and on their website.
Note: If you have misplaced printer driver disk, you can download drivers using the link below:
Welcome to Dell Support
Dec 09, 2009 | Dell 725 InkJet Printer
I have had this printer for about 2 years or so. It used to work. Now it gets frozen on the USB printer port page when I try to print. So I went to the dell printer driver page and downloaded the printer...
no need new printer first uninstall old printer drivers from computer then check your printer model number and download exact driver again then install.
Jul 13, 2009 | Dell 725 InkJet Printer
Unable to install dell 725 printer onto a dell vista laptop
Download Dell 725 Inkjet Printer driver and try to install.
Drivers and Downloads
Regards
Chittaranjan
Nov 22, 2008 | Dell 725 InkJet Printer
Laptop doesn't recognise printer
follow instructions below,
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Install printer drivers from CD or from download.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some peinter does not work on Vista
Sep 14, 2008 | Dell 725 InkJet Printer
Dell 725 installation problem
You may have to re-install the drivers for the printer. Did it come with a CD?
Apr 16, 2008 | Dell 725 InkJet Printer
Installing problem
You can refer to the following link to download & install the drivers for you printer:-
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_INKJET_725&os=WW1&osl=en&catid=&impid=
Apr 12, 2008 | Dell 725 InkJet Printer
Won't print black
MY DELL 725 PRINT WILL NOT PRINT IN BLACK INK. I HAVE A NEW PRINTER. I EVEN BOUGHT A NEW INK CARTRIDGE AND IT STILL PRINTS IN GREEN ONLY. WHAT CAN I DO TO HAVE MY DOCUMENT PRINT IN BLACK?
Jan 01, 2008 | Dell 725 InkJet Printer
Dell 725 InkJet Printer Logo
49 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
