Question about Panasonic PT-51G53 51" Rear Projection Television
I just got this tv from a friend for free and the picture is pretty dark. i know that rear projection tvs are usually darker but i was wondering if maybe i replace the bulbs or something i could fix it. I really have no idea what to do to fix it. Any suggestions?
  • 712 Answers
If the color, brightness and contrast settings can't do it, it might be the problem of your picture tube. It is a common problem with modern projection t.v.'s. You can fix this by just replacing the picture tube.
If you can get a working picture tube, of an age old t.v, it would be the best thing you are searching for. Old picture tubes were of superb quality, but the newly produced one's are not so good in quality as well as clarity.
Posted on Jul 15, 2010
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
Tv got dark and darker and now no picture what can be wrong? bulb bad?
If the model number indicated here is correct that set uses 3 picture tubes.
No bulb used on that model.
If model number is correct let me know and I have a few suggestions.
May 03, 2012 | Hitachi 61SDX01B 61" Rear Projection...
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
I was wondering if u know y my mitsubishi tv wasnt showing a clear picture i replaced the lamp with new one but it still shows a dark picture
This may be a model that has two mirrors. Mitsubishi could tell you if this is the case.
Some idiot had the bright idea to have optical unit shine picture into tiny mirror which puts it into large mirror in back; problem is tiny mirror if there is at bottom and facing up, dust or dirt get on it and picture brightness will diminish up to 70% or more.
If model you own does have two mirrors, the front of the set with the screens will have to be removed to clean it, not real hard and takes 15 minutes.
If you can confirm it has two mirrors I can tell you step by step how to remove screen unit and resolve problem. Usually if tiny mirror dirty it will happen over time, picture will gradually get darker and dull looking.
Let me know if want instructions, the set either has two mirrors or it does not.
SD TECH
Nov 03, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
Sony Grand WEGA KDF-60XBR950
Problem of darker picture in your TV shows expiry of Lamp (bulb) at rear of TV.
Aug 15, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Color is too dark
Unplug the TV,remove the front panel to gain access to the CRT sockets - loosen the screws that hold the sockets to the necks of the CRT's - now unplug and replug each socket from each CRT - this will remove any dust resistance on the pins of the CRT's - after doing this, the brightness level should go up.
Mar 11, 2008 | Hitachi 51F510 51" Rear Projection...
Picture is very dark and has a blue haze to the darker areas
Theres no adjustment except the tvs On screen disply is what you should ONLY fool with. Anytime you have the option you do and your not happy with it . GO for it!!! get a full refund and start over with another one or go to another store. Good Luck
Jun 21, 2006 | Mitsubishi WD-52327 52" Rear Projection...
Panasonic PT-51G53 51" Rear Projection Television Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
