Question about HP Photosmart M417 Digital Camera
Half of the buttons don't work
The zoom in/out buttons stopped working as well as some menu features. When these buttons are pushed, the camera make a little sound just like it did when they worked but nothing happens. What is interesting, is that when the back cover is removed, the button contacts work fine. I thought maybe the button 'points' were worn so added more tape to contacts which had no effect. Looked for a short with the cover, but could no find. This is my second hp camera and will be my last as they both have only lasted a year and hp seems to care less.
Hi, my M417 acted the same way. Would only power on and then any button would only make a little "tick" sound. I also tried taking the case off and my camera worked as well. What I spotted was that the switches are little metal domes which pop down in the center when the plastic button is pressed to make a connection between metal traces on the circuit board. The little domes are not attached to the board but are only held in place and located by some thick clear tape over the board. A couple of my switch domes had "drifted" out of position and so when in the case they had enough pressure for their edges to be making contact at all times so they were always on. I lifted the tape with a small knife blade and slid the domes back to where they belonged and now the camera is back to normal!
Posted on Aug 07, 2008
Zoom feature not working
So you're pressing the Zoom button but it has no effect, am i correct?
There can be 2 issues - small (dust/moisture), not small(inside button gone bad).
Small Issue: Keep the camera in sunlight(not very hot) for a while. (not loaded). Wipe off with clean lint-free cotton cloth. Keep it again in sunlight for a while. If moisture is the issue then it should go off, though i have seen in some cases it took 3-4 days and suddenly it started working.
If still no response from Zoom then the internal zoom small button has gone bad and needs to be replaced. Send it for repairs.
May 30, 2009 | Polaroid T831 Digital Camera
The lense will not zoom
Your camera has a zoom failure that can not reset by pushing menu buttons or else. Ask your local Sony repaircenter.
Regards,
Rob NL
Apr 24, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Instruction on zoom operation and also operation of flash on came
u have 3 problems here zoom,the flash and language ,ok to change the language hit menu .button then first word that shall be setup menu then word on the line number 3 and use right and left arrows to change ,the flash .turn the camera lens wheel on the pyramid sign u see on the front of the cam and then use the push button right side with zigzag sign to switch the flash mode ,push the button then up and down to zoom in and out
Mar 21, 2009 | Vivitar ViviCam 3750 Digital Camera
How to use the Zoom
I assume you mean when pressing the W or T buttons the zoom feature does not work. Try to reset the camera to the factory default settings and this should enable the zoom feature to work again. To do this go to Ok button and then to Mode Menu - then to Setup tab and then right arrow to Reset. hit the right arrow and you will see Reset Yes or No. Highlight Yes and press Ok. Camera should be in factory settings and zoom option will function.
Nov 13, 2008 | Olympus Stylus 600 Digital Camera
Sony DCR-SR82 has a faulty zoom
I have Sony DCR-SR82, the zoom on the camera just stopped working. Is there an easy fix for this?
Oct 24, 2008 | Sony Handycam® DCR-SR82 Flash Media...
LCD Screen stopped working on camera.
Have you tried the 'Menu' button? If you've turned off the 'Review' feature in the settings menu, your LCD screen won't show anything unless the 'Menu' button is pressed. If it doesn't come on when you push 'Menu' with a charged battery installed, your camera will need to be serviced.
Dec 25, 2007 | Nikon D40x Digital Camera
Stuck in manual mode
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
Oct 06, 2007 | Nikon Speedlight SB-600 TTL Flash
Canon SD550 Digital Zoom Not Working
Digital Zoom is best ignored in any camera it simply blows up a section of an image already taken, You can do that far better with an image editor in the computer. As for the Optical Zoom - it does indeed seem to be repair time- As it is only a year and half old- may be Canin will be sympathetic and offer a cheap swap out.
May 12, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
The SMART ZOOM is not working - doesnt either come up in SET UP menu?
I fixed my problem myself. Simply read the top of the camera1.gif where it says TO USE SMART ZOOM SET IMAGE SIZE TO LESS THAN 2.8M
Then go to the very bottom button on your camera (there are three) and press it and reset your image size.Then your zoom will work.
Problem solved.
Jan 11, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
HP Photosmart M417 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
