Question about Canon PIXMA MX310 All-In-One Printer
My printed paper have a lines what can i do? - Canon PIXMA MX310 All-In-One Printer
    Guru:
  • 366 Answers
It sounds like you need to run printhead alignment.
Though I cant find a manual to tell you how to do it but
You can download the software http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12764. You'll need to select your operating system.
Hope this should fix the problem.
Posted on Jul 15, 2010
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
My HP Deskjt F4280 will not print Avery injet 08371 business cards. I tryed the other number on the cards, 5371. Neither of them will line up proper. If I print on a blank paper it is printed correct. ...
you realy cannot print with that paper the ink cannot penetrate through, i have an experience here before and tried it on epson it print perfectly
Aug 07, 2011 | Office Equipment & Supplies
Ajbennett@gvec.netI have a 5250 kodak printer and when I copy something the paper comes out gray with black lines down the side. It does print. Why is the paper colored and have lines on it?
You are possible loading the paper in up-side-down. Try loading the paper flipped over. A lot of kodak photo paper have bar-codes printed on one side for the printer to scan and verify you are using the proper paper for the printing job you assigned to it.
Apr 08, 2011 | Cameras
My hp laserjet 2015n is printing a black line down the paper, what is this and can i fix it?
Hi:
One way to determine what is causing this is to do what is called a "panic stop" while printing a document. As the paper is starting to be fed into the printer shut it off and remove the toner cartridge.
You ideally want the paper to be under the print cartridge. Examine the image on the paper. Is the line visible on the paper at this point? If so, then the problem is with the print cartridge and it will have to be replaced. If the line is not showing up on the paper then the most likely culprit is the fuser section. This is were the toner on the paper is fused to the paper by heat and pressure. The heat roller or heat sleeve could have a line on it which would correspond to the line you are seeing on the paper.
Andrew
Mar 23, 2011 | Office Equipment & Supplies
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Extra Line when printing from a dos-based program
your printer paper size shorter than your PC dos-program print size setting, example: if use a letter size paper to print a A4 size file which should occur two paper go out..
so you need check your PC print setting or take a presetting paper size, make a size match between PC program and paper in printer .
hope you fix it, please take a rating let me know how much helped you thanks!
May 21, 2009 | Dell 5100cn Laser Printer
Tvs msp 250 champion printing in the same line
msp 250 champion dmp printer paper eskip settings ?
Apr 24, 2009 | Epson FX 890 Matrix Printer
Printing 2 lines on tab paper
I am printing on tab paper. Is it possible to have two lines print on a tab? If so, how? Thanks.
Mar 18, 2009 | Sharp MX-2300N Color Copier
HP D135 printed lines are angled slightly downwards left-to-right
twobells i have almost the same problem with the hp photosmart c4599 i have had no luck either
Jan 01, 2009 | HP OfficeJet D135 All-In-One InkJet...
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
Canon PIXMA MX310 All-In-One Printer Logo
125 people viewed this question
old marine
old marine
