Question about Creda IWD12 Front Load Washer / Dryer
Creda IWD12 filter.
I have un done the filter at the front of the machine (in the bottom left corner), and I am unable to close it again. It will only move a small amount and no matter how hard I try I cannot close it.
  • Big Al Jenno Apr 20, 2008
    Thanks, but it won't tighten - its stuck in a part-open positition. No matter what I do it will only move a small amount in either direction.
    Champion:
  • 207 Answers
I bet there's some foreign object that has dropped from basked trough the pipe leading to filter casing blocking it. Take a flashlight, get your head down an take a good look in filter casing. There's definitely some foreign object inside. Don't force the filter!
Posted on Apr 20, 2008
  • 487 Answers
As far as I remember it goes like this.
take the filter in your hand and turn the knob counter clock wise intill it almost comes off. Then gently shuff it into the filter hole. Push it in as far as you can and than tighten it again.
Maybe the following link will help you
CREDA IWD12
Condenser dryer
PULL OUT THE PLUG
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
Creda dryer kicks out breaker
could be one of the thermostats thats at fault, ,,
Sep 09, 2013 | Creda IWD12 Front Load Washer / Dryer
Creda iwd12 - how to remove the front
Its very simple to do when you fit them daily but first time is very difficult
Nov 03, 2012 | Creda IWD12 Front Load Washer / Dryer
A Creda condenser dryer TCR2, it went off won't work at all now
There is a lint filter inside the front of the m/c.
A filter at the bottom left of m/c,undo catches to release it, remove it and wash out under running water to thoroghly cleanit.
.Remove water container at top left front , and empty.
Make sure air intake and air out lets are clear, one at front right, and one at rear of m/c.
You can download user instructions.
Goto;;
www.hotpoint.co.uk
Click on (after sales), click on download user instructions, and follow the guide
Plz rate my solution.
Thanks.
Dec 29, 2008 | Creda IWD12 Front Load Washer / Dryer
My creda iwd12 front load is not working
If the m/c completed the wash cycle, it may be that the clothes have not rinsed, or incorrect prog selected, or incorrect temp selected,
Check to see if the drum actually goes round with clothes in, as a worn or broken belt will obviously stop the clothes from being washed.
Thanks.
Dec 16, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda IWD12 makes noise when spinning but still works ok
Either a concrete balance weight is loose or broken, or the main drum bearings are worn. Spin the drum by hand, and if it feels noisy or rough, then it is the main drum bearings that have failed.
Dec 02, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda Easy Load Dryer
Sounds like the timer is the problem, the reversing contacts have probably failed
Nov 09, 2008 | Creda IWD12 Front Load Washer / Dryer
Dial keeps turning and clicking
sue worth having inlet valve checked also have heater checked at same time ! is the machine draining ok !! if not there could be blockage in drain system or faulty pump good luck- regards bob btw
Feb 26, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda IWD12 Front Load Washer / Dryer Logo
391 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
