What is the btu capacity of intertherm a/c unit with model # 5584470?
3 Suggested Answers
pierre1811
  • 144 Answers
SOURCE: btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Posted on Mar 16, 2009
jas247
  • 844 Answers
SOURCE: I need to replace the
Welcome to FixYa!
You can purchase the filters at Appliance Factory Parts http://www.appliancefactoryparts.com/hvac/helpcenter/breakdowns/turbo-air/turbo-air-tas-24h.html
You can reach them at 1-800-955-7075
Appliance Factory Parts is one of the largest source of appliance parts.
Thank you for using FixYA.
Have a great day.
Posted on Aug 08, 2011
WHAT SIZE IS HEAT PUMP Q3RA-036K
Hello, this is a 3 ton unit. There are 12,000 btu per ton. The number 36 in the model number represents rhe tonnage of the heat pump, so 12,000 x 3 = 36,000 which is 3 tons.
May 09, 2012 | Heating & Cooling
What is the tonnage on an Intertherm S3RC-0336K.
Hello, the tonnage on this unit is a 3 ton unit. Your model number tells you. The 036 is the tonnage. There are 12,000 btu's per ton, so 36 divided by 3 =12 or in this case 12,000 btu's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jun 05, 2011 | Intertherm P3RC-036K Air Conditioner
Whirlpool window a/c model: acm152xlo How do I find out how many BTU's this unit has
That model number indicates a nominal capacity of 15,00 BTU, so it should be within 500 BTU on either side of that
Hope that helps
May 11, 2011 | Heating & Cooling
York model number ( H2DB024806A ) FOR THE ABOVE MODEL NUMBER I NEED THE TONNAGE ,BTU,SENSIBLE & TOTAL CAPACITY. As soon as possible. Earliest reply will be highly appreciated. Thanks In...
unit is 2 ton totla capacity 2 tons when mathced with proper equipment. BTU 24,000. Sensible heat only dervied from enthalpy chart once unit is installed. You will need a nate certified technician to assit you with the sensible and latent heat calculations for unit.
May 02, 2011 | Heating & Cooling
HOW DO YOU TELL IF 3,3 1/2 PR 4 TPN UNIT
Hi, you tell by the BTU"S it is. 12,000 BTU'S equal 1 ton of cooling. So, if you see a number in the model number like 024 or 030, and so on, 024 is a 2 ton, 030 is a 2 1/2 ton. Just remember this for each ton of cooling, you will have 12,000 BTU'S.
Shastalaker7
024, 030,36,042,48,060.
Jun 12, 2010 | Intertherm P3RA-042K Air Conditioner
Identify unit capacity.
The nameplate will provide a large amount of information, including the the manufacturer's name, model, serial, electrical requirements and the BTU rating or capacity that I believe you are looking for. Like the 120 volt sisters, the 240 volt unit should also have a nameplate. If unable to locate it on the chassis or frame of the unit in a similar location as the 120 volt, you'll have to look elsewhere. A www.google.com search on model number you provided (XHD183D) for this question indicates that it is a 17,900 BTU unit. If this is the correct model, case closed. If not, continue reading.
A good place to locate a nameplate if not plainly visible on the unit as it sits in the window would be on the chassis or frame behind the decorative grille. The grille is likely held in place by several clips and a screw or two. Shut off the AC and unplug it from the power source. Remove the filter as if to clean and carefully check for and remove screws and remove the grille.
I hope this helps!
Jun 07, 2010 | Carrier XHD183D Air Conditioner
Btu's
Mar 16, 2009 | Heating & Cooling
Size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
