Question about Carrier 38BRC036 Air Conditioner
24ABR348A0031010 compressor starts then stops. Carrier 4 ton R22 unit. Worked great, then fan runs all the time. Compressor will start for less than a minute, then stop. Basically compressor will not stay running. Capacitor tests good. Considering hard start kit. Freon levels seem to be correct. But without compressor running hard to get a decent reading. Not running high side has pressure. 150 to 175 psi. Low side has pressure too, 30 to 60psi. At first we thought it leaked down, but now am pretty sure no freon was lost. Going to do a recover tomorrow and weigh what I recover. I guess then reload correct amount. But really want to get compressor to run all the time.
  • 5 more comments
  • do-it-myself Jul 19, 2010
    Okay - Have an allstyle coil system in attic. R22 Non-Bleed TXV Expansion valve. Valve is Emerson RP31073 and confirmed with Allstyle that the valve should allow me to simply blow through the valve and should be open
    at atmoshpere when not connected. This valve is blocked solid at room temp with nothing connected.
    I cannot blow air through the valve. So we think we should replace the expansion valve. Do you agree?
  • do-it-myself Jul 20, 2010
    Removed Expansion Valve - Emerson RP31073. Non-Bleed. Valve is completely blocked and no air passes through at room temp. Called Allstyle that makes the expansion coil system in attic. Their tech says valve should pass air when at rest. Do you agree ? Am getting a replacement valve in a couple days. The store had a generic but I insisted on a direct replacement Emerson, it is a bolt in replacement. The generic needs some fittings attached. So we think the valve caused the blockage. Will reinstall. Pull vacuum, release freon stored in the compressor.
  • 455 Answers
Hello RR Hard start can't hurt BUT dosen't sound like the problem.Do you have a scroll compressor?They don't need a kit.Does it start every time?It could be short cycling on LOW PRESSURE SWITCH.If the unit is (pumping down) during the run time you have a restriction in the system.Make sure the service valves are open ,do you have a filter dryer colgging up or a bad TXV valve also could cause short run times.20-30 PSI the switch cuts out.
Posted on Jul 15, 2010
  • do-it-myself Jul 15, 2010
    Scroll compressor = YES. I agree that resctriction is very likely. Compressor shuts off, but before it does pressure climbs too high. We think it is the high pressure circuit shutting it off. You say no hard start kit needed. OK, I will skip that . Going to completely evacuate and capture all freon today, then I can remove filter dryer and replace. How can I test TXV valve ? Is it located next to, or on, expansion coil ? In this case in my attic.
  •  Christopher a Martin
    Hello RR Definately try the freon extange if there are noncondenseables in curcit it will cause problems.The txv test is (weigh in the factory charge )and nothing changes ,same symoptms.Is condenser coil clean?Is there enough air cooling it.High pressure could be overcharged unit & the recovery will slove.Let me know how you make out.The TXV is in the attic.
Heat pump drawing too many amps
If you are over drawing amps on start up and the breaker trips then you probably have a locked or"sticky compressor. You can check this by looking at the sticker on the compressor it will have a rating called LRA(locked rotor amps). If it your amp draw is at this or above this number then your compressor has locked up. Now if it reads lower than this then it needs helps starting. Either way you can try a hard start kit. Just follow the instructions on the package; they have just two wires to hook up: one will go to c on the capacitor and one to herm if you have a dual capacitor, If you have separate capacitors for the fan and compressor it just goes on the compressor capacitor. Easily identified by the higher rating. Now if your high rating is during run time then you should replace the compressor capacitor and see if your amp draw falls in line. If it doesn't you most likely have a bad compressor.
Jan 04, 2013 | Goodman Manufacturing Goodman GSH130301...
AIR CONDITIONER IS NOT COOLING, USING GAGUE, FOUND BOTH SUCTION AND DISHCHARGE PRESSURE VERY LOW. IT IS R22 4 TONS AC UNIT, SUCTION 10 PSI, DICHARGE 80 PSI. COMPRESSOR AND FAN RUNNING.
there is probably a leak in the systems somewhere, it needs to be inspected for a leak and charged with R-22 for proper cooling.
There is a stop leak for air conditioning systems available to licensed technicians to buy, might work if the leak is very small.
Aug 22, 2011 | Heating & Cooling
Carrier ac model 38ckc does not cool properly. Outside unit runs but air coming out of the top is cooler than the other units that we have. Just had a service replacing all the filters and coolant checked...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new compressor
Jun 20, 2011 | Carrier 38CKC036 Air Conditioner
Unit runs for about 5 min the cuts off. whats the problem?
Hi!!
It could be many things, the most common are Low R22 refrigerant, bad fan motor, bad compressor. obstructed condenser coil, bad starting relay, bad capacitor. among other things.
To check fan motor, set unit to HI Fan Only setting and let it run for a while, check that fan did not loose speed and it is not getting too hot.
If fan is OK, then turn unit to HI Cool 60-65 degrees and see what happens. Hear if compressor kicked in or if just made a humming noise and stopped. if this happens, replace capacitor.
Keep me posted!! Rate this post!!
Aug 14, 2010 | Kenmore 72055 Air Conditioner
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
COMPRESSOR NOT RUNNING, HOT
The high side/low side pressure equalization you describe is normal for a compressor sitting idle.
If you have an ohm meter you can check the compressor windings for opens and shorts. If your compressor is 3 phase as you state (this would be very unusual for a residential unit) you should have continuity across all 3 phases and no continuity to ground. Take the compressor out of the circuit before you check.
If the compressor does have crankcase heat, it should have been left on for at least 24 hours before starting the unit. Another cause for failure could be overcharging which could have resulted in refrigerant slugging back to the compressor.
Does the unit have any low or high pressure control safeties? If so, check them too - some have resets. You said the condenser fan ran so it's not likely the breaker blew, but check anyway and also check to make sure you have available power on all 3 phases.
May 03, 2009 | Heating & Cooling
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
Carrier 38BRC036 Air Conditioner Logo
504 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
