Question about Electrolux 504199 Dishwasher
As soon as we close down the lid the circuit breaker trips off ! our model is the 505048 passthrough dishwasher ck 0777
  • Electrolux Master
  • 3,247 Answers
There is a short circuit in the electric system in the dishwasher. As soon as you shut the hood, the circuit is completed and causes the breaker to trip.
You will need a technician to find the leaky part. Most likely the water is leaking into the motor / pump area causing a short circuit.
Best to disconnect from the mains and check for leaky gaskets. I believe this uses a 3 phase 400V which can be converted to single phase. So also make sure there is no unbalance in the mains power phases if you are using 3 phase supply.
Posted on Jul 15, 2010
  • Sam Jul 16, 2010
    Hi, it would have been nice if there was some feedback on this solution instead of just a 2 finger rating. It helps us to provide more assistance to the clients if they also post a comment to let us know why the solution was not so helpful after all.
When I put the top down as it clicks in it trips the mains lve tried different plugs in the house with the same result
YOUR CIRCUIT BREAKER MAY BE A RCD SET TO TRIP AT
250 M-AMPS VERY SENSITIVE
TO ME IT LOOKS LIKE YOU HAVE A ELECTRICAL COMPONENT OR CABLE SHORTING TO EARTH ,COULD BE SOME DAMP GOT IN SOME WHERE AND IS CAUSING A VERY SMALL ELECTRICAL LEAKAGE, HENCE TRIPPING THE CIRCUIT BREAKER. OR IT COULD BE A COMPONENT FAULT
PROBLEM COULD BE THE LID SWITCH ,GOT WET OR FAULTY, AND IT COULD BE COMPONENT AS PUMP OR MOTOR , AFTER YOU USUALLY CLOSE THE LID WHAT HAPPENS NEXT, DOES IT START FILLING WITH WATER/ COULD BE WATER SOLENOID VALVE FAULTY , WHAT I AM TRYING TO SAY IF YOU CAN REMEMBER WHAT HAPPENS AS SOON AS THE LID IS SHUT ,THAT'S WHAT MAYBE THE THING THAT IS SHORTING OUT, OR IF NOTHING HAPPENS WHEN YOU CLOSE LID NORMALLY UNTIL YOU SET UP CONTROLS
THEN THE PROBLEM COULD BE THE LID SWITCH OR WIRING TO IT FROM PROGRAMMER HOPE THIS IS SOME HELP. PS LEAVE IT OVER NIGHT TO DRY OUT IT MAY CLEAR IT'S SELF. GOOD LUCK
Nov 15, 2016 | Washing Machines
Asko d1756 power trips when door is closed
The switch in the door may have a bare wire touching the sides causing a short. Check a schematic for the proper way to remove and test the switch. Look for bare wires or any insulation cracks.
Mar 15, 2014 | Dishwashers
Kitchenaid Dishwasher trips the 60-amp main breaker but not 20-amp.
Its possible that there may be load on that circuit from other appliances. Had an issue myself with stove and laptop on same circuit.
Check other appliance attached to the 60amp circuit (microwave, stove, kettle etc)
May 13, 2012 | Electrical Supplies
Trips circuit breaker when door is closed
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Dec 15, 2009 | Baumatic 23 in. BDW5 Built-in Dishwasher
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Circuit breaker trips when dishwasher is off.
the problem will be in the circuit to the door
opening the door and it trips the breaker indicates that the hinge is rubbing on a wire or making the harness move to ground out
Nov 16, 2017 | Hotpoint 23 in. BF50 Built-in Dishwasher
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Mar 18, 2008 | Maytag SDE5401AYW Electric Dryer
When I turn on dishwasher it kicks breaker at wall outlet.
if it is tripping the breaker you have a dead short to ground check the water inlet valve on the left side front unplug the 2 wire connector to it and plug it in see if it stays on if you you found your short if not let me know.. but i will need the model # off the unit to get the wiring diagram
Jan 21, 2008 | Kenmore 17439 Built-in Dishwasher
Electrolux 504199 Dishwasher Logo
244 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
