Question about Microsoft Windows XP Professional SP2 for PC
Hi I have a problem in my PC... When I reformat the PC the Video Controller (VGA Compatible)gone... Kindly help me to reinstall the driver... Processor :Intel(R) Pentium (R) 4 CPU 2.80GHz 736MB of RAM Network Adapter :SiS 900-Based PCI Fast Ethernal Adapter. Thanks
  • 4 more comments
  • Carlo Martin  Sastrillo
    Carlo Martin Sastrillo Jul 15, 2010
    What is the model of the motherboard? Try to check the model and the chipset (SIS, VIA, Intel, etc) it will give you information on what VGA driver to download and where to download it.
  • edgar cristobal Jul 15, 2010
    It's LG ?!
    It's LG...
    not working...
    Field Value
    Device Resources
    IRQ 10
    Memory E0000000-E7FFFFFF
    Memory EC000000-EC01FFFF
    Port D000-D07F
    Field Value
    Motherboard Properties
    Motherboard ID 03/15/2005-SiS-661FX-6A7I4M49C-00
    Motherboard Name MSI 661FM (MS-6540)
    Front Side Bus Properties
    Bus Type Intel NetBurst
    Bus Width 64-bit
    Real Clock 200 MHz (QDR)
    Effective Clock 800 MHz
    Bandwidth 6400 MB/s
    Memory Bus Properties
    Bus Type DDR SDRAM
    Bus Width 64-bit
    Real Clock 133 MHz (DDR)
    Effective Clock 267 MHz
    Bandwidth 2133 MB/s
    Chipset Bus Properties
    Bus Type SiS MuTIOL
    Bus Width 16-bit
    Motherboard Physical Info
    CPU Sockets/Slots 1
    Expansion Slots 3 PCI, 1 AGP
    RAM Slots 2 DIMM
    Integrated Devices Audio, Video
    Form Factor Micro ATX
    Motherboard Size 230 mm x 240 mm
    Motherboard Chipset SiS661FX
    Motherboard Manufacturer
    Company Name Micro-Star International
    Product Informationhttp://www.msi.com.tw/program/products/m...
    BIOS Downloadhttp://www.msi.com.tw/program/support/bi...
    this is the model and manufacturer of motherboard pls help me!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 34 Answers
Hi pinggarci..
i found a driver for your PC...i think it will surely work for you..
i am giving you the link here to download that driver...the link is :
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17291&ProdId=2582&lang=eng
copy the above URL in your address bar....then click on the download
button on the page that will open...
i think this driver will surely work for you ....
and plz dont forget to rate me...
thanks....
Posted on Jul 15, 2010
  • 1,606 Answers
Usually the video card will run on one of the microsoft drivers that came with xp. There is the od one that will not work For those you need to get the driver from either the manufacturer of the video card or if integrated (built into the motherboard) the motherboard. On a laptop the video drivers are found on the manufactueres website.
From your description I would assume it is a desktop so the video card may be seperate or built in. If it is a common video card then you should have no trouble downloading it from the manufacturers web site. The problem is when it is a off brand those can be harder to track down. If it is a branded PC ie Dell, gateway etc then you can get the information or the drivers from thr website.
You will probably find other things that won;t work as well. Network cards and soundcards usually require the proper drivers and won;t work with the XP versions. You will want to also get any motherboard drivers which will allow XP to peroperlly detect any hardware and idenrify it instead of just getting the unknown device error.
To indetify everything if it isn't a brand name pc you will most likely have to open the case and look for markings. For an example if I opened the case and found the motherboard was a ASUS P4PG with video, network and sound then I would know to go to Asustek search for the downloads page for the P4PG and download everything there was. Then I would run the motherboard or system info drivers first. That will let xp know what it is dealing with. Then I would run video, set that up, then network. At this point you could get on the net and grab anyother drivers for sound usb etc that you need instead of having to copy them over.
This is a good excuse to buy or borrow a small USB flash drive. Even a 1 or 2 gb is more than you need. Then you can just save the drivers to the flash drive and when you have them all plug into the usb on your xp system you are setting up and run the drivers as needed.
When you have it all setup you should burn the drivers to a CD and save that someplace safe. Then if something happens you can just get it setup without having to hunt for anything.
I Reformat My Computer After i finish it The Audio Device on high Defination Audio Bus Video Controller Video Controller (VGA Compatible is missing) Please Help me Fix my PC.
Hi amrani_811,
Welcome to FixYa! How are you doing?
After you reformat your pc, you need to install the drivers. you can install the drivers by using the drivers disc that came with your pc or you can download it from the computer manufacturer's website (example: http://support.dell.com).
By the way, what is the brand of your pc or motherboard?
Hope that helps. Thank you for using FixYa.
Apr 28, 2011 | ASUS K8V-MX Motherboard
Hi, i tried to reformat my laptop and after that, my video controller vga compatible is missing and when i tried to look at it in the device manager the video controller has a yellow question mark. can you...
laptop always come with cd driver, use cd that come with laptop that you was bought
at device manager right click then click update driver, follow step by step the instruction, if it ask for cd driver insert your laptop cd driver
if you didn't have cd driver go to support center page of your laptop brand, you can download there
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | Computers & Internet
Hi I have a problem in my PC... When I reformat the PC the Video Controller (VGA Compatible)gone... Kindly help me to reinstall the driver... Processor :Intel(R) Pentium (R) 4 CPU 2.80GHz 736MB of RAM...
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Jul 15, 2010 | Microsoft Windows XP Professional SP2 for...
Video Controller (VGA Compatible)... Missing
You will need to go to the Toshiba WEB site, to the support/download page, search for the video driver for Windows XP for your model laptop and install it on your laptop. There may be several version, download the latest.
Dec 09, 2008 | Toshiba Satellite A105 Notebook
Device Drivers
Kindly download the requested drivers from the link below.
http://tinyurl.com/656myq
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - Proton
Oct 20, 2008 | Dell Inspiron 8600 Notebook
Video Accelerator Graphics Card
hello customer,
Now that you've reformatted and added drivers again its better to download the latest drivers either from your computer manufacturer's website or the website for your motherboard. If that doesn't help, you can get VIA drivers from http://www.viaarena.com. only then games wil be compatible. hope u find this udeful. thank You.
Jul 06, 2008 | Intel Video Game Consoles & Games
Hi i need to download drivers so my laptop will go on the internet,, its under device manager , the following are have a yellow question mark, ethernet controller , mass storage controller , multimedia...
i need drivers for my toshiba satellite M55-S3512. other drivers i have found from the toshiba web site but only the given below drivers i could not find.
1. Mass Storage Controller
2. Video Controller
3. Video Controller(VGA Compatible)
any one help from where i can find these drivers.
thanks
Feb 02, 2008 | Toshiba Satellite M55-S3512 Notebook
Have ? for video controller vga compatible
Hi wisesolomon7,
Try this link
Best of Luck,
Spare head 2.
Jan 04, 2008 | HP Compaq Presario V2000 Notebook
Microsoft Windows XP Professional SP2 for PC Logo
159 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
