Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cant get my Kingston flash drive
When i connect to pc its not working .......... nothing happens before it working smoothly...
  • 1,606 Answers
These do fail. The easiest thing to check is to stick it into a differant usb port or even a usb on a differant computer. That way you will know if it is the stick or the usb port that is the problem.
Unfortunetly there is nothing that is repairable on the drive so if it has failed you are out of luck.
Posted on Jul 15, 2010
Kingston DT200/128GB not able to detect
Go to your Admin Tools, computer management, disk management and if it shows up there but with a black line across the mini window it showing in, it will need to be enabled for windows to see it. if nothing like that is working, it may just be a bad drive. kingston 128Gb flash drives may not be formatted correctly for windows to see that its plugged in
Oct 18, 2013 | Kingston DT200/128GB 128GB DataTraveler...
I have a problem with my 16GB Kingston DT101G2 flash drive. I accidentally deleted all the installed files in the flash drive the first time I connected it to my PC, and now my PC can't recognize the...
NO...
Flash drives are just like any drive....nothing specific....you cant del system files...even if you format the pen drive the system files are there....
you pc is behaving funny as the USB port is having trouble / pen drive is not connected properly....as no specific drivers are installed fore the USB ports...it's all Windows drivers that sue the USB ports....
Sol
1 remove the pen drive
2 switch off and switch on the PC
3 reconnect the pen drive
it should work now...
for more PC related issues visit my site
reg
Kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | Office Equipment & Supplies
I have a kingston memory card it cant detect in laptop even with data cable also
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 29, 2010 | Kingston 4GB Secure Digital High Capacity...
My flash drive cant be formated
If your pc has virus it wont allow to format either the pc or the flash drive may have some virus in it try out to insert in virus free pc and try to format it..
Aug 20, 2010 | Kingston Computers & Internet
Kingston DataTraveler 64GB USB is not recognized by pc or laptop
Hey hi dude. As far as i heard, 64 gb drives are error prone to a greater extent. In some cases it is just showing 32 gb of storage space for the user. So better go to a nearby Kingston Service center and claim for a New replacement for your Pen drive. Am really sorry to say this. But there is no other go. Kingston provides you a nice customer service. Within one week, you will get a brand new drive as a replacement for your drive. Believe me!!!
Aug 02, 2010 | Televison & Video
My flash disk2.0 does no work.
try the device in another pc. if it works, then try it back in the pc with the issue. windows normally recognizes usb's if you cant get it to work, try it in a second slot on your pc. if it still doesnt work, your pc usb slot probably does not work
Jul 31, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Undetected usb drive
Pocket Fuzzies?
Get a bright light and look into the USB connector of the USB Drive. It is possible that there is lint, paper bits, cookei crumbs, etc in there and that is your problem. The outer 2 connections of the USB is DATA and the inner two Power. B/C it is able to flash,you are getting power... but the data lines may be dirty, covered, bent, etc.
Clean it up and try again. Flat toothpick, small ty-wrap or Proxident (dental/braces) brushes work well for this - DO NOT use anything Metal!! It will scratch the connectors and vastly shorten their life (they are GOLD plated)
Short of that, goto HP site and get their USB format tool (get it here: http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting... if that doesn't work, it is hosed and only I can fix it so let me know ;-)
Jan 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb flash drive
Kindly have a look over below FAQ link for trouble shooting.
FYI
http://www.kingston.com/support/USBFLASHDRIVES/faq/pcdt_1.asp
try on some other pc for confirming the defect
Jun 29, 2008 | Kingston flash memory card - 256 MB -...
Imation Swivel Flash Drive Cant detect
is it several times that youve used your flash driver at your office? and which side of the usb port did you plug it? coz when it is your first time to use your flash drive at your office and your plugging it at the front side of the PC. well there might be something wrong with connection and may cause damage to the board of the flash drive. if it your using it several times, well try to check at your PC, then do the following specs:
my computer (right click and select manage)
and under manage window ( select disk management )
try to see if your flash drive registered (you can see the drives of your PC) and see if theres a volume (either raw/ or theres a partition on it).
if not, well the board of your flash drive might be damaged, mostly these were caused by the power of the system, fluctuation is one of them, then improper plugging of the flashdrive.
Mar 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb drive is not deteded when plug into PC
Dear sir I am using kingston 2 GB USB pen drive it is suddenly not detected with my HCL leaptop. Plz kindly help me
Jul 01, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
112 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
