Question about Minn Kota Powerdrive V2 Bow Mount Trolling Motor with Foot Control Autopilot and Universal Sonar 2 (70 lb Thrust 60 Shaft)
I have a Minn Kota power drive v2 with digital maximizer only no auto pilot or other features. I just wired the 24V to it (and checked that I am getting 24V with a volt meter) and the motor won't turn left or right. The propeller turns and the speed control works but when I try to turn it left or right it doesn't move at all. I checked all connections and everything looks normal. Any ideas?
  • 157 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Hello raventrans. I suggest you contact www.minnkotoamotors.com/index.asp and ask for est#406, Dave.
Posted on Oct 19, 2008
  • 10 Answers
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
Posted on May 08, 2009
SOURCE: I lost istallation manual for minn kota power
Contact the people at this Email address. Minn Kota <Motors@johnsonoutdoors.com> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
Posted on Jun 05, 2009
  • 8 Answers
SOURCE: how does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Posted on Sep 07, 2009
bigcass
  • 35 Answers
SOURCE: is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Posted on Jan 19, 2010
WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
Can get replacement parts for my Minn Kota trolling motor FAQs
Apr 13, 2016 | Minn Kota Boating
What is amp. draw of minn kota 40pd? thanks
Digital Maximizerâ„¢
Digital Maximizerâ„¢. Up to five times longer run time on a single charge.
Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
Pioneered in 1985, Minn Kotas innovative Maximizerâ„¢ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
your manual is here and states it has a battery level meter.
http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
Minn Kota Motors
Jan 06, 2016 | Minn Kota Boating
The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
Is a minn kota mag 36 just 12V or 12V -24V run
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota 24v auto pilot. will track correctly
Usually this means that there is a crack in the coil cord or there is something metal close to the head of the motor.
The coil cord can be checked while you are out fishing next time by grabbing the cord (black coiled cord from base to head of the motor) and stretching it and pulling on it. If the motor reacts to the pulling then that's the problem.
best of luck!
Mike
Jun 20, 2009 | Minn Kota 55 AutoPilot Universal Sonar...
Minn Kota Powerdrive V2 Bow Mount Trolling Motor with Foot Control Autopilot and Universal Sonar 2 (70 lb Thrust 60 Shaft) Logo
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
