Question about General Electric Microwave Oven
GE Microwave model JE2160SF001-HUMS WHILE IT WORKS
Here a new one. GE Microwave model JE2160SF001 work but hums loud. Tested rectifier diode and HVCap. Tryed a new magnitron and it still hums.Reading 80.5 ohms on secondary winding and less than 1ohm on the other windings. None shorted to ground. I am at a loss not knowing what the secondary winding shoud be as it not shown on the scamatic.
5 Suggested Answers
SOURCE: LG MS-2143RSL MICROWAVE OVENT NO HEAT
hi i am suggesting that it is probably the magy as the res to grndis a bit low and therefore loading the sec supply down , just a thought
cheers grant
Posted on Oct 23, 2008
cactus bob
  • 267 Answers
SOURCE: HV diode producing resistance of 10 ohms.
you cannot check a microwave diode with just a mutli meter . you have to make a test jig take a 9 volt battery and a meter with dc volt scale set up the meter just like you would test a 9v battery .with me so far ? now remove one lead from the battery and insert the diode between the battery and the test lead .......take a reading . now reverse the diode take a reading ........ i just tested a diode before writeing this and this is what i got my battey volts where 9.2 v whith the diode inserted i got 7volts . reversing it i got .02 volts dc . a diode is a one way valve and mine is good because it passed curent only one way ...yours should be about the same ....... if you understand this please leave me 4 stars ! i even went out in the shop and tested a diode for you just to make sure my answer was correct
Posted on Mar 07, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker XL1400 stops heating
I agree.
Posted on Oct 09, 2009
citroenchris
  • 600 Answers
SOURCE: I have panasonic microwave model NN-S215MF,the
are you sure the magnatron was gone, that is rare, usually one or both of the diodes go (take out of cct and check with a meter
Posted on Jul 15, 2010
GE JE1860WH 04 microwave runs but want heat and it hums loudly.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Jan 01, 2011 | GE Microwave Ovens
I have a GE Spacemaker Model JVM16400BB004 over the counter microwave, that was working fine last night turn it on this morning and it lights up and the turnatable goes around and sounds just like it use...
http://www.gallawa.com/microtech/xformer.html
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
I own a Ge Microwave built in 2001. When I start it there is a loud hum. I suspect this may be the magnetron. Can you verify?
It may be a shorted high voltage rectifier diode or a bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 13, 2010 | General Electric Microwave Oven
Microwave does not heat
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
These answers will help me figure out if it's a control-level issue or a problem in the high voltage section.
Nov 28, 2009 | GE Microwave Ovens
NO HEAT IN "OTC" GE MICROWAVE
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("no heat"), as well as the answers to these questions:
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating anyting. All else appears normal.Manufactured Jan '05. Model JVM1870BF02
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit (JVM1870BF02), your symptoms (no heat), as well as the answers to these questions:
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1640BB 004 GE spacemaker Not heating
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.L
Oct 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave worked fine last night. This morning it won't heat at all. Makes a loud humming sound when turned on, everything else seems fine..?
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
(if it's not shorted, it's probably okay)
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting2.gif, testing, and locating components.
Sep 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER JVM1650 ''MICROWAVE MAKING LOUD HUMMING NOISE AND INSIDE REAL HOT WHEN DOOR CLOSED''WHEN DOOR OPEN DON'T HUM
When door open the microwave should not work at all, if the turntable and light come on with the door open , if they do , then this is an additional problem with door switch and must be fixed.
Regarding humming noise and no heath, Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
93 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
