Brivis Heater won't start. Display shows Code 56 error. What is this and what do I need to do?
5 Suggested Answers
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
  • 6 Answers
SOURCE: Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
Posted on May 15, 2010
Testimonial: "The error did indicate an HSI problem but it turned out to be a fault on the circuit board of the control module, thanks anyway"
jas247
  • 844 Answers
SOURCE: what causes a 71 error code on a brivis ducted
Welcome to FixYa!
Error Code 71 is caused by either of the following: 1. A very low setting on the controller less than 16 degs. 2. Or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
The power supply needs to be reset due to the fault being detected.
Solution:
  • Put the power supply to heater off first
  • Reset the heater panel
  • Press the button again to show EMS on
  • Then set the heater to the required temp. after turning on to the heating mode.
Thank you for using FixYa.
Have a great day.
Jas247
Posted on Jun 04, 2011
SOURCE: Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Posted on Aug 08, 2012
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Brivis heater HX 231-XA error code 58
I just called a technician out for a Code 58 error and it started working fine after he reset the controller. He checked for a blockage in the condensation pipe but it was clear so a bit of a mystery.
Apr 25, 2012 | Heating & Cooling
Code 68 appearing on LCD screen off a brivis LPG ducted heater
This is a error that can be fixed with a specific reset sequence. Follow this process carefully. The unit will not turn on for long and turns itself off after about a second so you need to execute step 2 immediately after step one.
Step 1 - Turn on heater
Step 2 immediately press no 1 on the keypad - this will display the error code H01 #68
Step 3 Hold down no 4 for approx 5 secs till the screen goes blank
Step 4 The screen displays all of the settings and resets
Note: you may need to do this a few times before it works - wait some time before retrying. If a reset will fix the problem this is the solution - if it is hardware a service call is required.
Jul 18, 2011 | Heating & Cooling
Brivis heating owners manual HE20i
I am having an error HO1 code#56 on my Brivis HE20i unit. It does not start. Initially had a code 55 and I did first press botton 1 followed by Fn and pressing 2 and 4 keys to make disappear the spanner. Can you help me, please?
Nov 01, 2010 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
