Question about Whistler GPS100 Galileo GPS Receiver
We have galileo machine MODEL : HABILIS III H Problem facing: Symptoms : Frequently machine shows ''ALARM -7'' while charging and Charging gets STOPPED. After restarting of machine again start working OK for 10 minutes.
We purchased a Timex Alarm Clock with USB Charging - Model T1210. We plugged it in to charge it - how do you know when it is charged?
I researched all data covering a Timex Alarm Clock with USB ports, and found none that allowed you to charge the clock with the USB port. The USB ports on the clock allow you to charge your mobile device using the clock power as the source. Your charging mobile device should show you charging complete. Hope this helps.
Aug 14, 2017 | Timex Audio Players & Recorders
My 11 galileo pro tablet will not power on after charging for 9+hrs.. When plugged in the blue indicator light flashes..What is going on?
The blinking blue indicator may be reassuring you that charging is in progress when, in fact, the battery may be dead or the charger is defective.
Jan 02, 2017 | Tablets & eReaders
My new alarm hs been charging for 12 hours and now is beeping what shall i do with it
get charger tested to see if voltage being supplied to new alarm. A voltmeter would show if the power transformer for your charger is ok as well as the power point.
Apr 15, 2014 | Home
Bullet Battery discharge problem -Frequently
I hav same prob, my bullet is 2008 model, from last 8 months frequently i faced tat starting problem cos of battery discharge. nd also i changed whole wiring harness, ammeter, battery, rectifier and coil (total 11000/- ) also bt still i facing tat*** problem... plz plz suggest how can i fix it up
arun gowda
Jul 20, 2010 | 2000 Enfield Bullet 350
I have a 2000 lincoln continental and the alarm has a mind of its own... goes off at random.. seems everywere i go they tell me to take it to lincoln.. is there a way to adjust the sensitivity
yes there is but unfortunately if it is a stock system I believe it has to be done at the dealer,but also if you car battery is getting weak even if it shows no symptoms of failer yet the car alarm will be the first to show problems,so to save some money have the battery and charging system checked first and also replace the battery in the key fob(remote)if all of this checks out then you may want to take it to a Lincoln/ford dealer.hope this helps
Jan 02, 2010 | 2000 Lincoln Town Car
Charging gauge bouncing back and forth starts after jump
sounds like a shorted field in the alternator
Nov 07, 2009 | 1981 Ford F 150
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
Whistler GPS100 Galileo GPS Receiver Logo
144 people viewed this question
Top Whistler GPS Experts
Will Halftowaite
Are you a Whistler GPS Expert? Answer questions, earn points and help others
