it is possible the heater is at fault try this first / then check motor / after these there could be an exposed wire shorting on the chassis . always remove plug from mains when carring out checks . good luck
i have a whirlpool washer model #sm828069 and two days ago it just stopped after the tub filled with water just before starting a wash cycle.i took all clothing out of washer but i still have standing water.i have checked fuse box unplugged unit and still nothing.is there a possible reset button or some way that i can fix the unit without calling a repairman?
Hotpoint WF740 washing machine - when switched on, all the lights flash rapidly in a cycle for about...
(More)
Hotpoint WF740 washing machine - when switched on, all the lights flash rapidly in a cycle for about 5 minutes before settling down and operating correctly. Any ideas on what is wrong?
wf440 two lights keep flashing and the wash cycle has stopped . Lights that flash are the mini load...
(More)
wf440 two lights keep flashing and the wash cycle has stopped . Lights that flash are the mini load light and the on off light
i have a 2yr old hotpoint wf541 washer, it wont seem to finish the cycle,the power light,mini load...
(More)
i have a 2yr old hotpoint wf541 washer, it wont seem to finish the cycle,the power light,mini load and reduce creases lights were flashing,ive took off the top and the back checked all terminals and wires.removed waste pipe and water in pipe everything seems in order. any ideas please
