Question about Remington 16" Electric Chain Saw
I have a model 098031j 16" electric chain saw.i need an oil cap with squeeze bulb part # 107512-01. Where can I purchase this.
  • 1,383 Answers
Bring the saw to your local lawn mower repair shop. bulb is a easy one the oil cap bight be a pain.. see if you can find alternative like a cap off a oil can ? vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Posted on Aug 24, 2010
Where are the oiling ponts to the bar to the ryobi 16 inch petrol chainsaw?
Hi
It's Lisa?
On an electric chainsaw there usually aren't what you would call oiling points.Somewhere,probably on the rear or one side of the case will be a bulb.It's also the screw on cap for the oil reservoir.
You fill that up with chainsaw bar oil,and as you use the saw every few minutes push the bulb down 2-3 times and it applies oil to the chain and gear in the case.The chain transfers the oil to the bar.
If this helps,would you rate my post please?
Thanks Bob
By the way,if you give me your model number I can look for a manual somewhere.No promises though,Ryobi likes to sell their manuals rather than download them.
Aug 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
McCulloch chain saw
check the plastic tubbing in the gas tank might need to be replaced or the primmer bulb has a pinhole in it.
Jun 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Oil leak on Remington electric chain saw model #111174-01
check oil lines and when storing saw stand on end or on side blade up.. vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
May 13, 2010 | Remington 16" Electric Chain Saw
What type of oil do I use in my remington 16 inch 3.5 hp electric chainsaw?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank you for using FixYa.
Apr 11, 2010 | Remington 16" Electric Chain Saw
What kind of oil uses on remington 14" electric chain saw?
FILLING OIL TANK
1. Remove oil cap.
Lou
Need ownewr manual
Your OM here:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From your OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
Page 8 has a pretty good chain illustration, I think mine is clearer for direction.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Electric Chain Saw
What type of oil is used in the remington 16" chain saw?
From page 9 of a M12510US (bar oil is SAE 30 with additives to help it adhere to the bar and chain):
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.
This is one of the most complete "Owners Manuals" Remington offers. If not your saw you can find your manual here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH Lou
Jan 23, 2010 | Remington 16" Electric Chain Saw
What type of bar oil do I put into a Remington electric chainsaw? (no manual, model #107624-01 ,16"bar
From page 9 of your manual:
FILLING OIL TANK
  1. Remove oil cap.
Like so much of what MrFixIt posts his opinion is based on BS. He can never take the time needed to provide any answer that actually requires thought or research!!!
Use bar oil available at any home center or hardware.
You can download your manual here:
Remington.com
HTH
Lou
If you did not rate his answer please give it the NOT HELPFUL rating it deserves.
Dec 31, 2009 | Remington 16" Electric Chain Saw
I need a oil primer button for a remington electic chain saw.model #108526-01.can u please help me find this part.thx
This are several part #'s (original and replacement) for the cap and bulb for your saw.
If your oil cap opening is 11/16" #107512-01, #079084-01.
If your oil cap opening is 7/8" the number is # 079084-02.
Although msservice (first link), and Master Parts (second link) says the 11/16" no longer available, you might try Grainger's (third link).
Most likely your not going to find the cap and bulb for the 11/16" opening however you could modify the other one. Try covering the opening with some plastic wrap and then wrapping the threads with Teflon tap. Then apply some Epoxy to the covered threads and placing the cap with the bulb removed over the opening. Once the Epoxy has started to set just unscrew the cap.
You could also heat up the plastic opening and expand it using a handle of a pair of pliers.
I hope something here helps.
http://www.msservice.net/desa/remington-chainsaw.html
http://www.masterparts.net/075475.html
http://www.grainger.com/Grainger/rp_parts_home.jsp?searchType=keyword&searchCriteria=remington&baseSearchType=product&doSearch=0
Oct 27, 2009 | Garden
I have pole saw model 108526-01 I need a new chain and a cap and bulb assembly where can I get these parts?
The good news is:
Your manual containing a parts list can be found here:
http://lawnandgarden.manualsonline.com/manuals/mfg/remington/100089-04_5.html
There is an IPL near the bottom, please save copy to your hard drive.
The part number for the oil cap & bulb assembly is 107319-02, I found it here:
http://www.remingtonpowertools.com/products.cgi?cat=11
I make no guarantees about availability. If you take the existing chain to a local chainsaw seller/mechanic they can almost certainly use it as a pattern to make a new chain
The bad news is:
Remington Power Tools have ceased production. Parts availability is limited to what is on hand. I recommend rather than purchase parts for this discontinued brand you put the funds toward the purchase of a new saw. Poulan offers 8 different electric models, have been in business for a very long time and are a subsidiary of Husqvarna. HTH
Lou
We can provide no further help for your saw.
Oct 08, 2009 | Remington Electric Pole Saw
Remington 16" Electric Chain Saw Logo
108 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
