Question about LG Flatron L1750S 17" LCD Monitor
Green discoloration is bothering the whole screen.
Pictures are then seen with dominant green colors which greatly affects the appearance and detail of pictures. My monitor model # is LG flatron W1943TV.
  • 11,361 Answers
Check the pins at both ends of the cable, also try it on another PC to make sure it is not the PC video card problem.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 18, 2010
The screen turns green after playing videos for 20 minures
The Video Controller works off of the RGB principal. RED/Green/Blue pixels. The mix color is dependent on the formation and density of the pixel and rates. When one or more colors are absent the only functioning color will dominate, and it is Green in your case. The screen liquid crystals in Red and Blue are failing and only a screen replacement will fix the situation.
Jan 04, 2015 | Toshiba C655D-S5200 Amd Dual-Core C-50 3Gb...
Screen turning blue green
Sounds like the ribbon cable has come loose either on the back of the screen or most likely on the motherboard. To correct either option means taking the laptop apart.
May 18, 2014 | Lenovo Ideapad S206 11.6 Inch Laptop -...
Washed out colors dominated by green and purple
There is fault on the chroma section and can be related to the board . Also a proper alignement cannot be ruled out unless the fault is seen in detail and so it is best to seek a consensus and estimate before you proceed , not to tamper unless there is a clear direction from the observation.
Dec 03, 2011 | Toshiba Televison & Video
There is too much blue on the screen & not enough green coloring
Have a very close look at the blue and see if it's perfectly uniform across the whole screen.
If it is then altering the hue or colour temperature settings in the menu may help.
If it's not then either there are heaps of pixel failures (appearing as small rectangular spots) or degradation of the polarisers (green may be affected more than the others).
If you show the menu, do the white areas appear bluish.
If the lamp is very old then colour changes start to happen.
Jun 23, 2011 | Canon Office Equipment & Supplies
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
THEN SEEN HAS A LITE GREEN TINT TO THE BOTTOM PART
Sounds like your main control board or the color wheel.
Dec 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Projection tv
the blue gun is not working properly which explains the dominance of green and yellow colors. you need to look after dry-joints on the blue gun circuit board, sometimes oil leakage from the lens may also affect the board
Mar 26, 2009 | Philips Televison & Video
Red color trouble
A picture or blank raster viewed from the front will have red marks if a portion of the image path from the green CRT to the front screen is blocked by debris or if the Green CRT is damaged from burn-in or other situations. If green is missing, red dominates virtually any image.
Severe CRT burn-in can occur when there is no sweep signal to a yoke. I have seen technicians removing yoke connectors on RPTVs in attempts to find shorted or suspect components.
Occasionally a damaged TV is sent back to customers as repaired and a service order for a new "fault or complaint" is initiated when the customer complains of the red or green marks or lines.
easyab
Jul 25, 2008 | JVC AV-56WP74 56" Rear Projection...
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
LG Flatron L1750S 17" LCD Monitor Logo
250 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
