Question about Watches
I am trying to figure out how to set the time on my odm MDD99B-2 Mr. Metallic watch.
I need to set the time on my 5208 Casio AQW 100 watch
ok instead of frickin lookin at the manual... just hold down the adjust button for five seconds then move the hands to 12:00 exactly then push adjust again for like 2 seconds then set the time and zone your in then your done... took me like a hour to figure this out... so dissapointed with myself
Jan 23, 2012 | Casio Watches
I just bought an ODM watch and I can't get it to display anything. How do I start the watch? Or does no display mean the watch needs a new battery? Thanks.
It sounds like it is the battery, I would take it back to the place of purchase to get satisfaction, and request having it replaced.
Dec 29, 2010 | Odm Watches
How do I set the time on a sports air warch
Q. How to set my watch A. The A and M button are located on the back of the watch LCD screen. When looking at the watch right side up the A button is the one on top and the M button is located below the A button.
1. Press A button twice, the month figure appears, press M to adjust the month.
2. Press A button once, the date figure appears, press M to adjust the date.
3. Press A button once, the hour figure appears, press M to adjust the hour.
4. Press A button once, the minute figure appears, press M to adjust the minutes.
5. Press A button twice to finalize the settings!
sports air watch
Dec 13, 2010 | Watches
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
How do i set the time/date on a pixel watch???
You will want to contact ODM on this one at their site:
http://www.odmdesignusa.com/eng/faq
Aug 24, 2010 | Bulova Watch
Hi, I have a casio protrek PRG-80T-7V(triple sensor). I haven't experienced any problems with it until recently. When I traveled abroad i passed through the ray gate in the airport wearing my watch....
Try to reset the watch.But first be sure that you capable of doing this.
Reseting the watch procedure:
1)Remove the back cover.Be sure that you have the appropriate screwdriver.Keep the 4 screws safe, not to loose them.
2)On the chassis of the watch (metallic surface) somewhere there is a hole with AC (All Clear) written nearby.
3)Use one little thin retracted paper clip (not totally retracted).Insert the retracted end of the clip into the hole, gently, until it touches the end and with the upper part of the clip contact the chassis (metallic surface). Wait for 1-2 sec and remove the clip gently.The watch is now reset.All functions have been set to factory settings.
4)Put back in place and with caution the back cover, respecting right (up-down) positioning and taking care that the O-ring gasket is well in place,first.
5)Holding in place with one finger the back cover,screw back screws gently and without applying excessive force (delicate job) until you meet resistance, in the following order:
Up-right,down-left,up-left,down-right.
After setting the time/day/date etc try to calibrate compass both ways as you did before.
I hope this will solve your problem.
NOTE:Again,be absolutely sure that you are capable of doing this.
It is a bit delicate job.If not,you better bring the watch to an official CASIO service center.
Apr 27, 2017 | Casio Protrek Triple Sensor PRG70 1BVDR...
I cant figure out how to set it
I just figured it out.
Hold the mode button down for 2 secs. The watch will start to blink to set the alarm. Press the mode button again and it will let you set the time. Use the set button to change seconds, minutes, hours.
Nov 01, 2009 | Timex 1440 Nylon watch
Cannot reset time
Hi to anyone with a wave ceptor, when you replace a battery you need to re calibrate the hands to 12 o'clock (also those with a 24 hour hand will need to be set to 24) this is called the home position, the same goes to stopwatch hands.
The hand setting settings vary wildly from watch to watch you will need to consult the manual or if you have lost it download thePDF file from casios support page, www.casio.co.uk , you will need adobe reader or a similar program that reads PDF files also you will need the module number, this can be found as a 4 figure number on the back of the watch, these instructions are easy enough to understand, i managed to set mine no problem.
Good luck!!!!
Apr 18, 2009 | Watches
Vestal G5 Global Traveler watch
THE REAL SOLUTION:
1. Hold down (light/el/set--the top right button) for 2 seconds to enter real time setting mode. 2. Press Mode key (bottom left button) to skip around to the different setting items. 3. Press Reset (top left button) to lower a setting. 4. Press ST/SP (bottom right button) to advance a setting (like increasing the time). 5. The day of the week will show automatically if you were correct in setting the year, month, date, and local city.
Apr 19, 2008 | Watches
Watches Logo
124 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
