Question about Kenmore Elite Oasis 27052 Top Load Washer
What is a code F on the machine? It stops washing
What is a code F on the machine? It stops washing and blinks F
    President:
  • 1,382 Answers
The reason for "F" flash is that if your machine doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely if it's frozen or stiff replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !!
Posted on Jul 15, 2010
Hitachie washing machine SF-95CJ. without completing the
Owner's manual? trouble shooting? Should have errore codes
No manual? try http://www.manualslib.com/
Mar 08, 2015 | Washing Machines
Maytag top load washer lights blink twice and stops working
Probably a error code. Check your Owner's manual, Troubleshooting section. No answer, try MFG customer service.
You may try unplug for several hrs. Black box may reset.
Feb 27, 2015 | Maytag Washing Machines
Hi, I'm using Panasonic Aquabeat NA-F130T1.(13kg),Fuzzylogic,Toploading. It stops at end of wash mode before rinse and blinks U12 code. Pls advise? Thanks.
Hi there, I'm using Panasonoic F130T1 washing machine.
my problem is,the washing did'nt complete n the water remains in the machine.
Pls advice as how i could solve this problem,tq.
Azhari.
Jan 11, 2013 | Washing Machines
Six blinking lights Whirlpool Duet
Could you please describe the problem you are having a little better please?
Nov 24, 2012 | Washing Machines
Whre5550k2ww
The motor/inverter on this washer stores fault codes. The LED you see blinking will blink once every second non-stop when in stand-by mode and twice every second non-stop when it should be running. If there is a fault code the LED will blink a certain number of times then stop for a few seconds. Some of the fault codes not allow the motor to operate. Post back the blink code.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | GE WBSR3140DW Top Load Washer
Bosch wfk2401. machine stops and lights start blinking " error code 03"
washing machine does not spin on any cycle , however the belt is fine. Any recomdenations
Jun 13, 2011 | Bosch WFK 2401
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Code 40
According to the Whirlpool installation and maintenance manual:
F _ _ “F##” code
Press PAUSE/CANCEL once to clear code.
Press START. If code appears again, call for
service.
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My machine stops and blink f1
unfortunately the only thing you cud look for in errors in washing machines is whether the door is closed properly or not. beyond that u will hav to look for a service technician the codes can be deciphered only by a service technicians of that particular company as error codes differ from company to company. The only thing I cud say is that there is a malfunction of one of the components in the machine sorry but if u hav the manual see if the error code u mention is listed in the manual
Aug 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis 27052 Top Load Washer Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
