Question about Toshiba e310 Pocket PC
I had toshiba e310, when i charge the ppc... after full, i used the ppc but not running. it's stop at opening screen. what happen with my ppc and how to fix it??
    Genius:
  • 1,040 Answers
It seems that you have overcharge the gadget. Had you unplugged the gadget after full charge? or after indicating full charge also you had not unplugged the gadget. Sometimes overcharging damages the software of motherboard or battery... But from your query, it seems that the in your case Software has been corrupted. So hopefully, after updation of the software your problem should be solved or else you have to get it serviced....
Hope this has helped you... Thanks.....
Posted on Jul 15, 2010
  • Tanu Widjaya Jul 15, 2010
    how, i can updating my software?
SOURCE:
My pocket pc e310 wont turn on. i only have the cradle and no ac charger. i have unplugged the battery for a reset but nothing happens after i plug it back in. when plugged in to the cradle, there are no...
The e310 can't use USB power to charge through the cradle. (It needs more than USB specs allow.) You have to supply +5v DC to the connector at the cradle or the e310 itself. Positive terminal is the center pin/hole, negative terminal is the outside barrel of the plug.
Jun 02, 2011 | Toshiba e310 Pocket PC
Pocketmac toshiba e310
Check out mark-space software, it worked well for me
Feb 08, 2008 | Toshiba e310 Pocket PC
Toshiba pda e310
you may proceed to http://pcrepair.toshiba.com
Locate the most convenient service center in your location. Call the service center to confirm the issue.
Good Luck
Feb 02, 2008 | Toshiba e310 Pocket PC
E310 pc screen not functional
I charged the my e310 pc up and the touch screen doesnt work, but does light up, etc.
Sep 12, 2007 | Toshiba e310 Pocket PC
Cant turn my toshiba e310 on
The only solution that I found was a hard-reset... Simply remove the back cover of your Ppc removing the four little screws located on the cornes. Then disconnect the battery plug which is a rectangular white plastic piece with four red and black wires. Hold on for about 10 minutes. Plug it again and put the back cover... BINGO!!! The only little problem is that you just lose all your data... so, unless you have a backup (if you are using MS Outlook in your desktop system you have one) you will be prepared to type again all your data.. Good Luck.
Sep 19, 2005 | Toshiba e310 Pocket PC
My PC not turn on
Toshiba Pocket PC e310 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (19 of 104).
Sep 08, 2005 | Toshiba e310 Pocket PC
My PC not turn on
The Toshiba Pocket PC e310 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (19 of 104).
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Toshiba e310 Pocket PC Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
