Question about Haier Mechanical Air Conditioner HWF05XC7
My ac I purchased last night worked fine last night, today I left it and when I came home the humidity was way up. It is making a slush sound. It is installed correctly. The place I purshcasd it says I cannot return it so I need help to correct this. I am a woman and never had this before.
  • Haier Master
  • 1,711 Answers
From what I undestand the AC have gather a lot of water in the unit to condenser. This mean that last night their were a lot of humitity in the room so the AC unit absorve a lot of it inside the unit. The AC in normal conditions evaporate this water ouside in the inviroment. However if the humitity absorve is more than it can evaporate then you should check the drain pan
Posted on Jul 15, 2010
Car stalls when ac or defrost on
Sounds like the compressor is dragging the engine down. The compressor runs in ac and defrost mode. You might try unplugging the compressor to verify.
Jul 21, 2013 | Ford Cars & Trucks
97 intrepid shut off fine last night, today will
sounds like a fuel pump or maybe check on the asd relay or fuel pump relay try taking them off and tap on them then try to start if no start sounds like a fuel pump or timing belt issue. good luck
Jan 05, 2010 | 1997 Dodge Intrepid
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
My rooftop Trane A/C unit shows high humidity on the thermostat, will not cool the house during the day but cools fine at night. What could the problem be? Also, how can I lower the humidity in the house?
High humidity causes Icing of the cooling coils. Avoid constant running of the a/c. Meaning let the AC pull the house dow 2 - 3 degrees at a time.. The unit shutting off will allow the ice to melt. Make sure the drain is clear by going outside and chkg for drainage. Once the house is reasonably dehumidified the ac can be set and left on its own.
Jul 06, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
I am no tgetting sound from external speakers
Power down your machine
Unplug everything from it
Open it up
Remove your sound card and put it back in
Reverse the step and boot your machine
If it still doesn't work then you'll need to replace your sound card. You can find really good ones on Amazon for $25 or so.Remember to always turn off your speakers before you plug them into your computer. Since they are probably powered via AC adapter that surge of power could have shorted out your card. Good luck!!
Oct 01, 2008 | Microsoft Windows XP Home Edition
Fan making loud noise like it needs oiled
Most of the fan motors can be oiled. You will have the slide the ac forward and remove it from the case to access it. You will find yellow pull pins on each end of the motor, a lite drop or two is all that is needed.
Aug 16, 2007 | LG Electronic Window Air Conditioner
Tv won't come on
any lights come on if not check ac cord if not check outlet if not then open it and check fuses
May 04, 2007 | Sanyo DS31520 31" TV
Haier Mechanical Air Conditioner HWF05XC7 Logo
59 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
