Question about Canon PowerShot SD1100 IS Digital Camera
Is not a problemasking if my canon ixus 8015 was compatible in 4GB or 8GB sd memory card?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD cards top out at 2GB. The IXUS 80 IS is compatible with SDHC cards, 4GB and larger.
Posted on Sep 30, 2012
  • kakima Sep 30, 2012
rmaddox5
  • 5 Answers
SOURCE: MEMORY CARD
I would think that as long is it is a sd memory card then it would be compatible since the camera uses the sd card and the 4gb is for photo storrage
Posted on Jan 26, 2008
SOURCE: canon digital ixus 700
I understand that it takes a maximum of 2GB. Still loads of photo/video capability. Don't make the mistake I did of buying a 4GB SDHC card for it. It won't take it.
Posted on Sep 28, 2008
old marine
  • 2105 Answers
SOURCE: maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Posted on Feb 24, 2009
  • 102366 Answers
SOURCE: Inserting either a 4Gb or 8Gb SD card results in
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Posted on Jan 07, 2010
F1xer
  • 415 Answers
SOURCE: is canon digital IXUS 55 compatible with 4gb SDHC
The maximum amount the Canon sd450 can support is a 2gb card, anything more and you 'll just get error problems.
Posted on Aug 16, 2010
4gb kingston canon ixus 50
The IXUS 50 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jun 04, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
What's your problem?i put a 4gb memory card in my canon SD 200 and it says error why
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Mar 05, 2012 | Canon PowerShot SD200 / IXUS 30 Digital...
Memory card error SDHC Toshiba
I've checked out your Canon Powershot SD550, and this previously written answer definitely applies to you, Wendy:
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Mar 23, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
I got a new 4gb sd memcard for my 2005 canon ixus 50, screen shows " memory card error" "card locked". tried switch on card as u suggested, no diff.
The IXUS 50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Canon Cameras
Sd card
There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
I hope that helps.
Mar 20, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
I hve a canon ixus 8015 When I put photos from
Its a one way street...from camera to computer...not the other way around. Doing that will eventually corrupt the card and sometimes even the camera.
Jan 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Ixus 40 maximum SDHC card
Your camera is not compatible with SDHC type cards. No 4gb cards for you. It looks like 2gb (non SDHC) cards are the biggest you can use.
Feb 25, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
My Powershot 450sd camera is not reading 4GB SDHC
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
Dec 29, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Can ixus700 upgrade to use 4gb memory card?
The ixus 700 is only specified to be compatible with SD memory cards (and MMC cards). The protocol for SD cards only covers up to 2MB. Cards of higher capacity are the SDHC (high capacity) protocol, but this protocol did not exist when the ixus 700 was introduced. As far as I can tell, there is no way to upgrade to be compatible with the newer protocol.
Dec 09, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
MEMORY CARD
Dec 31, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD1100 IS Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
