I went to turn on my sony pcg k47 and the scree only showed the viao and intel logo and then the screen went black so i pressed F2 upon startup and checked my biossettings and still no windows ..
  • 305 Answers
Your windows might have been corrupted ... if it is vista or 7 you need the os setup dvd to repair the files
Posted on Jul 15, 2010
I have a sony viao all in one desktop model num pcg-252l i replaced the screen and i trun it on and it lights up but it stays all white
A white screen meant the LCD controller was not working - what you saw was the backlight without polarization in front of it. If the cpu fan isn't spinning, that means the system board doesn't detect the right startup conditions. You probably connected the inverter improperly and it may be preventing booting, or you may have damaged a component with static.
http://www.experts-exchange.com/questions/27848125/PCG-252L-Sony-All-in-One-Viao-No-Display.html
Mar 29, 2016 | Sony Computers & Internet
When i press the power button the VAIO logo shows then a Intel logo after that there is just a blank screen and windows wont load. what should i do?
Upon starting go to bios settings, click "F2" to access the bios, go to to exit, choose "Default Maximum setting", save upon exit....restart.
Hope that helps you out, msg. me is there are still problems.
Thanks for asking FixYa!
Aug 15, 2011 | Sony VAIO VGC-RA840G PC Desktop
Brand new Dell Vostro 430, in troublefree use for two weeks, sudden does not start up any more. After turning the Vostro on: - it shows the startup screen with the Dell-logo in the center, the intel...
Press DEL on startup and select "last best known config that worked" If that doesn't work you have probably corrupted the Win registry.Will need to take back to store, beware that if its a software fault you will have to pay and may lose all your data n the HDD!!!
Oct 16, 2010 | Computers & Internet
My Viao wont get past the Viao logo and tells me that no operations system can be found & the recovery utility won't load
put recovery disc in to drive reboot press F2 to go into boot options, set cd/dvd rom to first boot save and exit reboot.when all done F2 again and then Press F9 set to default.
hope this helps.
Apr 29, 2010 | Sony VAIO VGN-NR120E/S Notebook
Screen is dead
  1. turn off the computer
  2. take off the ac adapter and remove the battery
  3. reseat RAM/memory
  4. without the ac adapter and battery, press and hold down the power botton for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
hope this helps
Mar 02, 2010 | Sony Computers & Internet
Hi fellas, i'm having trouble with my vaio pcg-k47. the fn key is on all the time, and instead of having letters on the key board, there are some that are wr5ting nnumbers. can u help me fix that? Can u...
Press the Function (Fn) key again to deactivate it.
Please check if the "NUM LOCK" is enabled. If it is enabled then press it to disable to resolve the letter/number key issue.
You may disable the Function key by removing the VAIO Event Services Utility or HKSERV Utility from the Startup.
1. Click on the Start, select RUN, in Run command type: msconfig and press the Enter key.
2. In the MS Configuration Utility, un-check the VAIO Event Services Utility or HKSERV Utility and then click on Apply then OK.
3. Then, restart the Computer. This will disable the Function key in the Computer.
Good Luck!!!!!!!!!
Nov 18, 2009 | Sony VAIO PCG-K47 Notebook
How do I restore my Sony Vaio PCG-Kits orginal
try strart --> all program --> accesories --> system restore
Nov 18, 2009 | Sony VAIO PCG-K23 Notebook
MY LAPTOP TURN ON YOU HEAR THE LOGO SOUND,SCREEN TURN WHITE,HARD DRIVE KEEP TURNNING ON AND OFF BUT NO PICTURE,JUST A BLANK WHITE SCREEN. I HAVE A SONY VIAO PCG-Z1VA MODEL.
Insert your Windows installation disk and select Repair Windows rather than Install. Hopefully it will allow you to boot properly.
Sep 23, 2009 | Dell Inspiron 6000 Notebook
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Nov 30, 2008 | Sony VAIO PCG-K23 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
