Question about LG DLE2532W Electric Dryer
DRYER WONT HEAT
HOW DO I REPLACE THE CIRCUT BREAKER/FUSE IN MY DRYER
    Novelist:
  • 112 Answers
The thermal fuse and thermostat is located on the heater assembly under the right side of the drum.
You will have to take the unit apart to get to the heater assy.
Posted on Jul 25, 2010
Gas dryer pops circuit breaker
Number 1 Do NOT! use this dryer until it is fixed, it a a fire hazard. You will need to get the entire power circut checked for shorts. Make sure the motor has been checked under the same conditions as it is used in the dryer, with a capasitor and changing directions etc.
NEVER EVER !!! Change a Circut breaker with a higher value than the one which is there. You will burn the house down. This is a serious fire risk. The power cables over heat and arc then burn, if the breaker is not right.
Feb 01, 2014 | Dryers
Gew9200LW duet dryer
If this is a 220 VAC dryer use a voltmeter at the wall plug. Chcking from common, usually the leg with the angled blade, to each of the hot legs, each with the straight blade. You need to have 110 VAC in both of these. If there is only 110 at one of the legs the motor will run but the element will not heat. If you find only one leg has 110 VAC try a new circuit breaker in the breaker box. If the breaker is bad it will appear to reset, but still not send current. If you have 110 on both legs check in the dryer for a burned off wire at the timer or element.
Jan 06, 2014 | Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
My worldpool dryer truns but will not heat up??
Thank you for contacting Fixya.com.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Check the thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) that is mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation.
Please check the bellow link to have an in-depth knowledge as to when the dryer wont heat up...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have any further query.
Have a nice day.
Nov 29, 2010 | Whirlpool Dryers
No heat
most likely cause is element next would be circut breaker or fuse, or thermo fuse
Sep 20, 2010 | Kenmore 62972 Electric Dryer
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
Where is the circuit breaker or fuse on a Kenmore Gas Dryer?
no heat usually means your only getting110 volts into your dryer.....you need the full 220volts to run heaters....with voltage meter you checkwires on the plug OUTLET...or inside back cover REDwire to WHITEwire =110v.........BLACKwire to WHITEwire =110v.....REDwire to BLACKwire =220v. you probably have aBAD 220V. 30 amp circut breaker..or if still using FUSES one is burnt out (In house electric panel) or burnt off RED or BLACKwire in back of dryer.....
May 09, 2009 | Kenmore 63942 Dryer
Dryer does not heat
Verify 220 volts at the terminal block where the cord attaches.
Also, 120 volts from each leg to neutral at the same check point.
Check the thermal fuse at the top of the heat element canister for continuity.
Check the high limit switch at the heater terminals for continuity.
Mar 12, 2009 | Kenmore Dryers
Dryer will not heat but turns on and spins but no heat.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
Mar 11, 2009 | Dryers
LG DRYER MODLE DLE0332W
If it is running, chances are one of the thermostats are gone. You have two on the heater bank, a high level and a safety, have them both changed.
Sgt 48
May 25, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
191 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
