Question about Singer 7462 Mechanical Sewing Machine
Just bought a serger profinish. Have threaded it correctly but the machine won't run. Spent several hours trying to see what was wrong. Checked with the book and rethreaded it and still will not sew. It is plugged in correctly and the motor is running but does not feed or move the needle.
  • Singer Master
  • 1,388 Answers
Ensure the front door is fully closed, some machines have a safety switch to protect user.
If this is a new machine, ask the dealer where you bought it for advice, phone to arrange a demo with them, even a lesson might be worth considering......if there is an issue with the machine, they will need to assist under their warrantee obligations.
It is very rare, but some machines will slip past quality control, after all 10% of things are made on Monday morning !!
Posted on Apr 24, 2008
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
I have a Tiny Serger. The thread keeps coming out of the needle when I try to sew so it is not making the chain. What am I doing wrong?
The order that you thread the machine in is also important. Thread the loopers (things underneath) first, thread the needle last.
Aug 18, 2014 | Singer Tiny Serger TS380
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
My brothers serger is skipping stitches
Many problems can cause a serger to skip. Start with the correct new needles and good quality thread. Skips can be tension a clearance or timing issue or the amount of thread pulled out by the thread guides. This is not something most consumers can repair. Even with the service manuals they can be difficult. I have spent thousands of hours working on sergers.and skipping at high speed can be difficult to solve. Some brands are more user friendly to service. This like will show some of the common settings and tools needed for a serger service.
Oct 13, 2013 | Sewing Machines
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
TRYING TO THREAD THE 634d I DON'T HAVE A MANUAL I HAVE ORDERED ONE DO YOU HAVE A DIAGRAM OR ANYTHING THAT WILL HELP ME PLEASE!
I have this serger, also. A friend (who knows sergers) and I spent 2 hours today trying to get the lower looper threaded--with no success! There is a diagram in the door of my machine, but it is still very confusing! I'm taking mine to the shop on Monday and have them thread it and show me how to do it!
May 13, 2011 | Janome MyLock 634D Mechanical Sewing...
Is there any other thing I can do to stop the thread from the upper looper from breaking after about 30cms of sewing. there is no sign of it being about to break. I have changed thread, needles and...
it could be due to one or more of the following
  • Threading is not correct.
check that bobin is not snagging thread,
remove bobin and remove any dust and fluff from bobin area
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Correctly thread machine.
  • Replace needle with correct size.
  • Properly insert needle.
  • Start machine at a medium speed.
  • Check threading order.
I hope this was helpful
Jan 05, 2011 | Husqvarna Huskylock Computerized 910
Problems threading a Europro serger
Probably the needle hit one of the loopers and left a burr on it that is catching the thread. Run your finger nail acroos the edges of the loopers. If you find a burr it can be polished off using very, very fine crocus paper from a hardware store.
Or the needle hit a the upper looper and knocked it slightly out of position.
After you have it threaded (correctly) turn it slow by hand and watch the loopers very closely. You will probably see what is happening.
Dec 08, 2008 | Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
