Question about Haier CPR09XH7 Portable Air Conditioner
Air Conditioner is freezing up
My Air Conditioner coils under filter keep freezing up. I have had it on a week straight due to the heat. The compressor turns off when the temperature gets low enough from the frost on the coils.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
Fix freeze up
There is a reason they freeze up 1. low on freon..2 evaporator coil needs cleaning(inside coil)..3. very dirty air filter, any one of these for a an air conditioner may freeze up... due to a number of other reasons. The most common reason for an air conditioner to freeze up is low on refrigerant.
Jun 27, 2015 | Heating & Cooling
Ice on coils of heat pump not cooling
Which coil?, indoor or out? Indoor coils freeze due to clogged filters, low freon, blower motor not working. Outdoor coil freezing could mean, in rare cases in cooling mode, reversing valve not shifting.
Oct 02, 2013 | Carrier 52CQ-312-4 Comfort Series Heat...
My AC keeps freezing up
Hello, the unit will freeze up either due to a airflow problem, suchs as dirty filter, dirty evaporator coil. Or a low refrigerant charge
Jul 06, 2012 | Goodman GPH1324H21A WallWindow Air...
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
MY AMANA AIR CONDITIONER COILS FREEZE UP WHEN IN USE
Hello, the indoor coil will freeze either due to low airflow or a low refrigerant charge. Start be checking the air filter, evaporator coil and blower wheel to mae sure they are clean.
Jun 14, 2012 | Heating & Cooling
Daewoo air conditioner dwc f1220cl keeps freezing up. Filter is clean.
for some reson its not getting enough air flow across the evaporator . check behind the filter and be certain the coils are clean . also if its still iced up you might shut it down and take a hair dryer to it to get all the ice off the coils . as the restrictions due to ice are makeing it worse .. Let me know if it helps ..
Jul 24, 2011 | Daewoo Heating & Cooling
Coolin coli making ice, his filter and coil as clean,out side tempreure is 03centg. can u explain(details) me about gas charging.
You can't charge on cool mode as your indoor temp is very lower than minimum temp of air conditioning. ., 16 C degree. And also due to low ambient temp your coil is getting freezes. Keep in heat mode and check still icing your coil, it's short of gas. And that time you can do gas charging by keeping cylinder up right. Helpful?
Jan 08, 2011 | Mitsubishi MSZ-A15NA Split System Air...
The air unit is frezzing up and the air is never under 70 degress in the house! whats making it keep frezzing up?
Hi, when the unit freezes up, it is either low on freon, a plugged a/c filter, or the evaporator coil is dirty and will need to be cleaned. When the evap. coil freezes up, the blower motor can't blow air through the coil. Check the filter, and behind the filter to see if the coil is dirty, just remove the screws to excess the evap. coil on this unit. Make sure the blower motor is running up to speed also. You will know. If the coil is dirty, try and clean it the best you can and replace the filter. If it continues to ice, you will need to have the freon level checked> These are the # 1 causes of coils icing up. Please let me know how it turns out.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration, Contractor
Aug 17, 2010 | Intertherm P3RA-048K Air Conditioner
My ac unit keeps freezing up on the pipes and keeps leaking water everywhere. what could it be the problem.
If you own indoor pets you will want to change the return air filters monthly like religously. You may also need to have the A-Coil other wise none as the evaporator coil cleaned manually. It is located inside the air handling unit inside the house somewhere. It could be restricting the air flow across the coil with daner and dust and/or deris. Sometimes it can be difficult to clean but with care and lots of elbow grease it can usually be done. Be careful not to bend the fins! Once this is completed and the unit still freezes up! Then you can be sure it is low on refrigerant 90% of the time! Cleaning the A-Coils is something you should do or have done anually!
Aug 06, 2010 | Goodman CLQ36AR49 Air Conditioner
Window air conditioner unit frosts over and stops working.
COILS USUALLY FREEZE UP DUE TO INSUFFICIANT AIRFLOW ACROSS THEM. IF THE FILTER IS DIRTY, THEN IT SHOULD BE REPLACED IF IT IS DISPOSABLE, OF CLEANED IF IT IS A PERMANENT ONE. THE ONLY OTHER REASON FOR A FREEZING COIL IS A LOW FREON CHARGE. IF THE UNIT HAS A LEAK, AND IS STILL UNDER WARRANTY, THEN RETURN IT TO THE MANUFACTURER. HOPE THIS HELPS. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 26, 2009 | Amana AC103E Thru-Wall/Window Air...
Haier CPR09XH7 Portable Air Conditioner Logo
66 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
