Question about Canon PowerShot S230 / IXUS 179 Digital Camera
Compact Flash Card
Hi Can you tell me how big a Compact Flash Card i can put in my Canon S230 please ? Glen
  • 3 Answers
Any size your looking for ... probally not larger than an 8 gb card would be fine
Posted on May 21, 2008
Getting write error on Kingston 32gb Ultimate 600X Compact Flash Card
at the command prompt (pc/notebook) type chkdsk x: /f where x is your flash card
Dec 03, 2013 | Kingston Electronics - Others
I have a canon S230 shur shot digital camera, now for about 5 years. Excellent camera. All of a sudden,I can't take photo's.(good battery,compact flash, etc.) I can still review slides taken, but the...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 10, 2009 | Canon Cameras
It keeps coming up with "CF" when i turn the camera on,I have checked the covers and there all ok?
CF means Compact Flash
Compact Flash is a type of memory card.
Your camera is telling you that there is a problem with your CF card.
Either it is not installed, full or damaged.
There should be a door on side of the camera that provides access to the CF card so you can check if it's there.
You manual explains the details or you can stop by a camera store where someone would be able to help you.
If this helps please vote for this solution.
Aug 19, 2009 | Canon PowerShot G5 Digital Camera
I have a Canon EOS 350D, Compact Flash card freezes my computer
Instead of connecting via the camera, just use a USB card reader and put the CF card in that.
Mar 17, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Hello all i have a canon pixma mp830 and i was trying to print a cd and every time that i put the disc in the slot and press print it tells me that there is no disc there for printing please help
I don't know this machine as such but I just looked at the manual and perhaps I should have put my glasses on but I did not see that you can print on or from a CD, compact disc (~5.25 inches in diameter). If you meant to say that you could not print from a compact flash memory card, small rectangular device about an inch in L/W and 3/16 thick, then you might not have the correct file type on there. You need to have jpg images on there not RAW or edited images with a non jpg format. Is the message really saying there is no disc or there are no photos in memory card? No photos could mean that it is empty or the wrong format.
You can download a user's manual from Canon if you need one.
K2
Jun 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
No pictures
Look in the card slot with a flashlight to see if there are any bent / misaligned pins. If so, remove batteries and card and Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed). It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
May 27, 2008 | Canon PowerShot S230 / IXUS 179 Digital...
White bands appearing across pictures
Mikrofiber towel and a few drops of wather.
Clean the lense even if looks clean.
Try to reset the camera in the menu to the factory settings.
If not help service only.
Nov 11, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Canon powershot S230 Camera will not take picture now
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Oct 28, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Problem downloading pictures from memory card
Hi flashlal - I have a Cannon PowerShot S400 and I had a similar problem which uses a compact flash card. I could only view a few photos and it seemed like the rest were gone. I verified that my photos were on the compact flash card when I installed it in my pc and navigated to the compact flash card (You can do that by double clicking on the "My compute" icon). Then double click to the directory to where your memory card is located and navigate through the files. I noticed that my photos were there because the file size was in the hundreds of kilobytes (700KB and up), but the names of all the files were corrupt - they had symbols in the name. I figured at this point I had nothing to lose so I did a "check and repair disk" on the compact flash. To do this: take note of the directory that your memory card is located in (it should be something other than C:). Once you know where your memory card is located, you go to your start button on the PC, then to run. A pop-up window appears.The command to repair your disk is "chkdsk /f", however you have to tell it the directory of where your memory card is located. For me my memory card was in the E: drive so I had to type:
chkdsk e: /f
Once it finished running I went back to the my computer window and navigated to my compact flash folders. I looked at my photo names. I had to rename all my photos by putting the extenstion of "JPG" back as the file type. Once I did this, I could then view my pictures. The only thing I lost was the added information that my camera puts on it like the date, time, and camera setting used to take the picture. I was fine with not having that because it was more important for me to retrieve my pictures.
Good luck.
Sep 26, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S230 / IXUS 179 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
