Question about HP Pavillion G50-111NR Notebook
Why is my laptop so hot and running all the time? it's only 1.5 years old?? programs are slower too.....
  • 532 Answers
It is normal for hp laptop to get hot when it is running. my own hp laptop will burn my lap if i put it on my lap while running.
If your laptop is slow, free up space in the hard disk because if the hard is fill up, it can make the laptop to be slow.
If it is still slow, then the laptop is contacted with a virus. scan the system with updated anti virus and delete the virus on your laptop or you format the laptop and re run windows.
Thanks for contacting Fixya.
Posted on Jul 15, 2010
It dont work on lenovo
There are many reasons y0our laptop is running slow.
1. Make sure the ventilation holes of the laptop are not blocked with dirt, or blocked by placing laptop on your lap, or a non-hard surface. When the CPU gets hot, it will throttle down to run slower. You can install a temperature monitoring program to determine if the CPU is running too hot. 2. If the temperature is within normal range, then check to see the amount of free space on your HDD. Keep at least 10% or more free. 3. If that is ok, then you may not have enough ram to run all the programs. Windows 7, or 8 should have at least 4GB or more RAM. 4. If that is ok too, then you may have a lot of unnecessary programs running. Run a virus scanner program to get rid of viruses, etc. 5. Uninstall unused programs. Sort by date to see which programs were installed most recently, By doing this if you can remember when you started having problems, you can uninstall programs installed around that time that may be causing your problems. As you can see a lot of things can cause slowness. Good luck!
Mar 31, 2015 | Lenovo IdeaPad Computers & Internet
Old Dell Inspiron 6000 can it run faster?
Hi, there could be a few issues to resolve.
1. run a anti virus
2. download a free trojan removal tool and run it
3. go to control panel-add remove programs and remove anything you dont use/ need
4. run defrag, if you havent run defrag in a while, this will seriously slow up your pc
May 31, 2012 | Dell Inspiron 6000 Notebook
Lenovo T61 running slow - 3 years old..
There are so many reasons can cause your Lenovo T61 computer running slow than it used to, it is hard to identify just what might be dragging down your Lenovo's performance, let alone implement the necessary technical adjustments to fix it.
So if you want to address the issues more easily, I'll recommend you try a Lenovo speed up software, available here: http://www.speeduplenovo.com/
Over 10+ small utilities packed into one to help detect & fix all slowdowns in 1 click.
May 16, 2011 | Lenovo ThinkPad T61 Notebook
Ihave an acer laptop,,,.,., i was installed w7 on my laptop,,that time my laptop work slowly,,, and also the black spots on monitor screen,,
See whether you laptop have the minimum system requirment to install Windows7, windows 7 needs more graphics support than others os.
May 09, 2011 | Computers & Internet
I have a laptop and it runs so slow. The battery life is beyond horrible so I have to keep it plugged up at all times. I have not used this laptop alot until now because I am a college student. Its almost...
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Mar 21, 2011 | Everex StepNote NC1500 Notebook
My laptop is sort of running slower and I wondered if it was because my space is almost full on my laptop? And I also wanted to know if I can do anything to make it go back to normal. One other thing is...
First of all, simply delete your browsing history and cookies. Websites will sometimes download cookies or copies of their pages to your hard drive for faster loading later. The unfortunate thing is that this can slow down your pc. Using your browser, delete your browsing history, cookies, and all offline content.
If your computer takes a long time to boot up, take note of how many programs you have loading on start up. Pay attention to the bottom right of your screen and watch the icons. Having a large amount of programs loading on start up will make your boot times considerably slower. Open these programs and tell them not to start on start-up, or simply delete them if you don't use them.
Sometimes spyware or other malware will be downloaded to your computer and can adversly affect performance. I suggest downloading a spyware deleting program like Lavasoft's AdAware. It is free and reliable. When you use it, make sure that you update the definitions each time to make sure you search for the newest spyware. Try running the tests at least once a week.
Mar 15, 2011 | Computers & Internet
I have an aspire 3053 laptop it is so slow its unbelievable is it possable to change the memory to speed it up its about 3 year old
Is your computer running Windows Vista Home Basic?
Does it have 512MB of RAM installed?
If yes to both questions, then adding 2048MB of RAM will _definitely_ speed-up your computer.
See: http://www.pcmemorystore.com/Acer-Aspire-3050%5E1733-ram.htm where you can buy 2GB (2048MB) of DDR2-4200 RAM for $38 US.
The usual cause for a "slow" computer is too-many programs running at the same time (not too many programs installed onto the disk-drive) competing for too-small amount of RAM.
Turn the computer off.
Disconnect the AC power-cord.
Flip the computer over.
Remove the battery.
Remove the screws over the memory cover (at the centre of the bottom).
You'll either see a stick of RAM, or an empty slot for RAM.
Remove any existing RAM, and insert the new stick of RAM.
Replace the cover.
Insert the battery.
Connect the AC power.
Boot it up, and it will run _MUCH_ faster.
Oct 21, 2010 | Acer Aspire 3050-1733 Notebook
Acer Computer... extremely slow response time.
try installing ccleaner. It is free software from download.com
once installed go to the tools then to startup and disable anything running in the startup. then run cleaner. If it is still running slow change the ram. There may be some kind of driver issue with your speakers. They may also be bad speakers. Who knows' but the netbooks are not going to have the best quality of sound anyways. worst case buy headphones or external speakers
Jan 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Switched off at random twice yesterday and is running way slower
NP--Whenever I find that type of problem, I first suspect malware, then power or heat, and then maybe programs that just shouldn't be running.
Try running MSCONFIG. Shut down programs or utilities that you don't recognize.
May 20, 2009 | Toshiba Satellite A300-0CF035 Notebook
HP Laptop Low Memory
try changing your CMOS battery
Apr 06, 2008 | HP Pavilion dv4000 Notebook
HP Pavillion G50-111NR Notebook Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
