Question about Dishwashers
As soon as power is turned on to dishwasher there is a beeping noise and F1 is lighting up on touch pad screen. What do I need to do?
  • Dishwashers Master
  • 2,605 Answers
Hello, welcome to FixYa. The first question I can answer easy, what you first need to do is provide a make and model of the unit in question :0) I will watch for your reply. macmarkus :)
Posted on Jul 15, 2010
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
May 22, 2011 | Kenmore Kitchen Ranges
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Jan 11, 2011 | Ovens
Digital screen reads F1--oven will not light
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 14, 2010 | Amana ACF3325 Gas Kitchen Range
Displaying F1 error
Apr 04, 2010 | GE JGRP17 Gas Single Oven
F1 error code and beeping on a ge doubleoven
Hello there:
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
There is a code F-1 appears on the screen along with the beep sound
F1 means defective touch pad or ERC. Turn off the power to the range. Get to the ERC. If the pad and the ERC are incorporated, replace it. If not disconnect the touch pad ribbon from the ERC. Make sure there are not loose wires. Assemble the control panel back. Turn the power on. If F1 comes back - replace the ERC. If not -replace the touch pad. Good luck.
Oct 28, 2009 | Magic Chef Ovens
F1 code with noise on my Migic Chef 3868xrw
Not a good sign, may indicate bad oven control module. Try this test:
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
Sep 13, 2009 | Maytag Kitchen Ranges
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Kenmore 8114p643 showing f1.
F1 is either a bad electronic control board or a bad touch pad.
You find the solution on :kenmore oven with "F1" error
I quote:
"You have either a bad ERC (clock) or a bad touch pad.
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
If you can't find a new ERC you can send yours to stove clock repair and get it repaired!"
Dec 14, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
F1 Displayed
Carol, The F1 error code could be cause a failed ERC(EOC,Clock assembly)or a faulty touch-pad. To check the ERC and the touch pad, follow the steps below : -Disconnect renger's power cable. - Gain access to ECR's back. - Disconnect the ribbon cable between the ERC and the touch-pad - Reconnect renger's power cable and switch on. - If you will get the F1 and the beep,it means that the ERC is fault and should be replaced. - If you don't see the F1 code and don't have the beep, you should replce the touch-pad. Good luck !
Jun 13, 2006 | Kenmore 92329 Electric Kitchen Range
Dishwashers Logo
114 people viewed this question
Top Dishwashers Experts
Owen Barnes
