Question about Makita 9005B 5" Electric Angle Grinder
Angle grinder eats carbon brushes
I've just gone thru my 3rd makita grinder 9005B in 2 years. am i abusing them? I'm cutting rock (flagstone, ledgestone) with diamond bit blades. They work great then suddenly start eating carbon brushes. Armature damaged by rock dust? Is there a brand or model with enclosed armature? Thanks for your help.
  • Makita Master
  • 885 Answers
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Posted on Aug 23, 2010
How to fix makita 5" grinder
It is time to replace the trigger switch.
May 08, 2014 | Makita 9005B 5" Electric Angle Grinder
How do I change th4e3 brusheson a Makita grinder?
If it is the one listed in the header 9005B first unplug the tool and then get a good screwdriver and you will find 2 brush caps that need to be removed and pull the brushes out, Be careful not to crack the brush caps and if you do think about replacing them. Let me know if you need more assistance.
Mar 30, 2011 | Makita 9005B 5" Electric Angle Grinder
Need manual for makita angle grinder model 9005 b,also spindle nut wrench.
Go to www.makitatools.com, type 9005 in the search block and you'll get a page where you can get the manual and parts break down in PDF format. The spindle nut wrench is Part #782412-6 and can be bought at most power tool stores or ordered on line at places like ereplacementparts.com.
Aug 16, 2010 | Makita 9005B 5" Electric Angle Grinder
Breaks support rings in all blades
are you using the proper inner blade flange?? that is the only thing that I can think of that would cause your problem
Jun 12, 2010 | Makita 9553NB 4" Angle Grinder
Angle grinder issue
Do you have the securing nut on the correct way? Basically the inner surface of the nut needs to be flat against the blade for it to work correctly and hold the cutting disc in place Usually the nuts are reversible to fit either flat discs or rounded disc heads. It's either that or you do not have the right size bore on the diamond disc for your grinder.
Jun 15, 2009 | Black & Decker 4 1/2" Small Angle Grinder
Armature problems
Unplug tool and then remove the brush caps and brushes, at the front of the tool are 4 screws that need to be removed after removing them you might have to pry the gearcase from the motor housing and then it should just pull out if there is no problems with the field having been hot and melted. Let me know if you need further assistance
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Can't get grinder to turn on. Checked brushes, cord, trigger/switch. Any suggestions?
Did you check continuity to the field/brush holders. They have a garter spring that sometimes became overheated and broke. It seems like you have done everything else. Let me know
Feb 25, 2009 | Makita 9005B 5" Electric Angle Grinder
Makita 9005B 5" Electric Angle Grinder Logo
559 people viewed this question
Top Makita Saws Experts
mikenearman
Marvin
Marvin
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
